Salta al contenuto principale
SuperSonic Matrix Mid SC-999 Battery Replacement
Cosa ti serve
  1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: passo 1, immagine 1 di 1
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Battery Replacement: passo 2, immagine 1 di 1
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Battery Replacement: passo 3, immagine 1 di 2 SuperSonic Matrix Mid SC-999 Battery Replacement: passo 3, immagine 2 di 2
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: passo 4, immagine 1 di 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: passo 4, immagine 2 di 3 SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Battery Replacement: passo 5, immagine 1 di 3 SuperSonic Matrix Mid SC-999 Battery Replacement: passo 5, immagine 2 di 3 SuperSonic Matrix Mid SC-999 Battery Replacement: passo 5, immagine 3 di 3
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
Conclusione
Altre 2 persone hanno completato questa guida.
Baylor, Team 6-1, Shaver Spring 2015 Membro di Baylor, Team 6-1, Shaver Spring 2015
BU-SHAVER-S15S6G1
4 Membri
18 Guide realizzate
Un commento
Link to the soldering technique guide!
Josh Lewis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,360
