Salta al contenuto principale
SteelSeries Stratus Duo Mainboard Replacement
Cosa ti serve
  1. SteelSeries Stratus Duo Mainboard Replacement, Remove the sticker: passo 1, immagine 1 di 2 SteelSeries Stratus Duo Mainboard Replacement, Remove the sticker: passo 1, immagine 2 di 2
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
  2. SteelSeries Stratus Duo Mainboard Replacement, Unscrew the back cover: passo 2, immagine 1 di 1
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
  3. SteelSeries Stratus Duo Mainboard Replacement, Reposition the back cover assembly: passo 3, immagine 1 di 3 SteelSeries Stratus Duo Mainboard Replacement, Reposition the back cover assembly: passo 3, immagine 2 di 3 SteelSeries Stratus Duo Mainboard Replacement, Reposition the back cover assembly: passo 3, immagine 3 di 3
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
  4. SteelSeries Stratus Duo Mainboard Replacement, Disconnect the interconnect cable: passo 4, immagine 1 di 3 SteelSeries Stratus Duo Mainboard Replacement, Disconnect the interconnect cable: passo 4, immagine 2 di 3 SteelSeries Stratus Duo Mainboard Replacement, Disconnect the interconnect cable: passo 4, immagine 3 di 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
  5. SteelSeries Stratus Duo Mainboard Replacement: passo 5, immagine 1 di 2 SteelSeries Stratus Duo Mainboard Replacement: passo 5, immagine 2 di 2
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
  6. SteelSeries Stratus Duo Mainboard Replacement, Disconnect the battery cable: passo 6, immagine 1 di 3 SteelSeries Stratus Duo Mainboard Replacement, Disconnect the battery cable: passo 6, immagine 2 di 3 SteelSeries Stratus Duo Mainboard Replacement, Disconnect the battery cable: passo 6, immagine 3 di 3
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
  7. SteelSeries Stratus Duo Mainboard Replacement, Remove the back cover assembly: passo 7, immagine 1 di 1
    • Remove the back cover assembly.
  8. SteelSeries Stratus Duo Mainboard Replacement, Unscrew the thumbsticks board: passo 8, immagine 1 di 1
    • Use a Phillips screwdriver to remove the two 6.8 mm-long screws securing the thumbsticks board.
  9. SteelSeries Stratus Duo Mainboard Replacement, Disconnect the thumbsticks board: passo 9, immagine 1 di 3 SteelSeries Stratus Duo Mainboard Replacement, Disconnect the thumbsticks board: passo 9, immagine 2 di 3 SteelSeries Stratus Duo Mainboard Replacement, Disconnect the thumbsticks board: passo 9, immagine 3 di 3
    • Grab the thumbsticks board with your hand and disconnect it by pulling it straight up and out of its socket on the mainboard.
    • Remove the thumbsticks board.
    • For reassembly make sure to correctly align the ten pins with their socket on the mainboard.
  10. SteelSeries Stratus Duo Mainboard Replacement, Unscrew the mainboard assembly: passo 10, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 6.8 mm-long screws securing the mainboard assembly to the case.
  11. SteelSeries Stratus Duo Mainboard Replacement, Remove the mainboard assembly: passo 11, immagine 1 di 3 SteelSeries Stratus Duo Mainboard Replacement, Remove the mainboard assembly: passo 11, immagine 2 di 3 SteelSeries Stratus Duo Mainboard Replacement, Remove the mainboard assembly: passo 11, immagine 3 di 3
    • Use your hand to remove the mainboard assembly by tilting it out of the plastic cover.
  12. SteelSeries Stratus Duo Mainboard Replacement, Unscrew the trigger button covers: passo 12, immagine 1 di 1
    • Use a Phillips screwdriver to remove the four 7.2 mm-long screws securing the trigger button covers to the mainboard.
  13. SteelSeries Stratus Duo Mainboard Replacement, Remove the trigger button covers: passo 13, immagine 1 di 3 SteelSeries Stratus Duo Mainboard Replacement, Remove the trigger button covers: passo 13, immagine 2 di 3 SteelSeries Stratus Duo Mainboard Replacement, Remove the trigger button covers: passo 13, immagine 3 di 3
    • Use your fingers to pull the trigger button covers off of their shoulder button breakout boards.
  14. SteelSeries Stratus Duo Mainboard Replacement, Remove the mainboard: passo 14, immagine 1 di 3 SteelSeries Stratus Duo Mainboard Replacement, Remove the mainboard: passo 14, immagine 2 di 3 SteelSeries Stratus Duo Mainboard Replacement, Remove the mainboard: passo 14, immagine 3 di 3
    • You are left with the mainboard.
    • If you replace the mainboard, compare it to the new one. You may need to transfer over some components, e.g., the rubber pads for the D-pad and the action buttons, or even desolder the shoulder button breakout boards.
Conclusione
Adriana Zwink
Membro da: 12/18/19
48.265 Reputazione
167 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 443
