Salta al contenuto principale
SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement
Cosa ti serve
  1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: passo 1, immagine 1 di 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: passo 1, immagine 2 di 3 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: passo 1, immagine 3 di 3
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 2, immagine 1 di 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 2, immagine 2 di 2
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 3, immagine 1 di 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 3, immagine 2 di 2
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 4, immagine 1 di 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 4, immagine 2 di 2
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 5, immagine 1 di 1
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 6, immagine 1 di 2 SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: passo 6, immagine 2 di 2
    • Desolder the four button pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on Come saldare e dissaldare componenti elettrici.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
Conclusione
Altre 3 persone hanno completato questa guida.
Kyle Chang
Membro da: 01/24/19
1.152 Reputazione
7 Guide realizzate
Cal Poly, Team S18-G1, White Winter 2019 Membro di Cal Poly, Team S18-G1, White Winter 2019
CPSU-WHITE-W19S18G1
4 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,171
