Introduzione
When accessing the microphone, be careful of ripping the wire connections or breaking the plastic casing. Make sure to follow this guide attentively to ensure that these issues do not occur.
Cosa ti serve
Lift the edge of the cushion and pull out slightly.
Work your way around the cushion until it comes off completely.
Repeat for the other cushion.
Remove the three 5mm screws with a Phillips #0 driver head on the headphone with the microphone.
Pull up on the wires connected to the circuit board using tweezers to remove the circuit board from inside the headset.
Altre 7 persone hanno completato questa guida.
9 Commenti
Is there any place where i can get this cable? I also need a new mic for the wireless pro but steelseries dont sell parts. Somehow it came off and i lost it.
The left earpiece on mine has a different screw type than phillips for some reason. I think it’s a kind of hex screw but I have hex heads and none worked. Strange that the left and right earpieces use different screws.
