Salta al contenuto principale
Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement
Cosa ti serve
  1. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: passo 1, immagine 1 di 2 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Opening the Device: passo 1, immagine 2 di 2
    • Remove the six silver 11.4 mm Phillips #0 screws
    • Pry open the device using a plastic opening tool if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    Chiedi a FixBot
  2. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Styrofoam Pad: passo 2, immagine 1 di 1
    • Now that your device is open, remove the Styrofoam pad that covers the main circuit board. The adhesive should allow you to remove and replace it with ease.
    • Do this carefully to avoid tearing the pad.
    Chiedi a FixBot
  3. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: passo 3, immagine 1 di 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: passo 3, immagine 2 di 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing the Circuit Board: passo 3, immagine 3 di 3
    • Remove the eight black 7.2 mm Phillips #0 screws from the top of the circuit board and remove the circuit board.
    Chiedi a FixBot
  4. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: passo 4, immagine 1 di 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: passo 4, immagine 2 di 3 Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Removing The Micro SD Reader: passo 4, immagine 3 di 3
    • Unscrew the one 7.2 mm Phillips #0 screw from the plastic piece covering the microSD reader.
    • Then, unscrew the two 7.2 mm Phillips #0 screws from the microSD reader and remove it from its fastening.
    Chiedi a FixBot
  5. Spy Net Ultra Vision Goggles MicroSD Card Reader Replacement, Un-Soldering the Wires: passo 5, immagine 1 di 1
    Chiedi a FixBot
Conclusione
USF Tampa, Team 4-5, Brown Fall 2014 Membro di USF Tampa, Team 4-5, Brown Fall 2014
USFT-BROWN-F14S4G5
3 Membri
6 guide realizzate
1Commento della guida
Where do you get the replacement parts?
clsutliff - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 8
Ultimi 30 giorni: 45
Tutti i Tempi: 740
