Salta al contenuto principale
Spin Master Boxer Robot Battery Replacement
Cosa ti serve
  1. Spin Master Boxer Robot Battery Replacement, Robot Screen: passo 1, immagine 1 di 1
    • Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
  2. Spin Master Boxer Robot Battery Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #00 screw driver, unscrew the four 4mm screws in each corner of the bottom panel.
  3. Spin Master Boxer Robot Battery Replacement: passo 3, immagine 1 di 1
    • Carefully remove the bottom panel of the Spin Master Boxer by lifting up, away from the main body of robot.
  4. Spin Master Boxer Robot Battery Replacement: passo 4, immagine 1 di 2 Spin Master Boxer Robot Battery Replacement: passo 4, immagine 2 di 2
    • While holding onto the axels of the wheels, gently pull the top panel of the robot away from its body.
    • Be aware when removing the panel that multiple wires connect it to the body of the Spin Master Boxer.
  5. Spin Master Boxer Robot Battery Replacement: passo 5, immagine 1 di 1
    • Remove the plastic screen from the body of the robot. It should come off easily as it is not attached by anything.
  6. Spin Master Boxer Robot Battery Replacement, Robot Battery: passo 6, immagine 1 di 2 Spin Master Boxer Robot Battery Replacement, Robot Battery: passo 6, immagine 2 di 2
    • Lift the top panel away from the main body of the robot to expose the yellow battery.
  7. Spin Master Boxer Robot Battery Replacement: passo 7, immagine 1 di 1
    • Insert index finger in between battery and plastic shell of robot, and push battery out of the battery holder toward the wire.
  8. Spin Master Boxer Robot Battery Replacement: passo 8, immagine 1 di 1
Conclusione
Altre 2 persone hanno completato questa guida.
Lauren Roide
Membro da: 04/16/19
739 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G1, Maness Spring 2019 Membro di Cal Poly, Team S1-G1, Maness Spring 2019
CPSU-MANESS-S19S1G1
4 Membri
10 Guide realizzate
3Commenti sulla guida
Any tips on where to buy a replacement battery?
Chad Laughlin - Replica
In fact it’s easy, was able to put 1000 mah Lipo 952540 with a little stretching of battery plastic holder
Anton Litvinov - Replica
can we replace boxer’s USB slot?
Buchukoy Jimenez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,612
