Salta al contenuto principale
Sostituzione lente lettore DVD Nintendo Wii
Cosa ti serve
  1. Sostituzione lente lettore DVD Nintendo Wii, Copertura anteriore: passo 1, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii, Copertura anteriore: passo 1, immagine 2 di 2
    • Usa uno spudger in metallo per rimuovere le coperture in plastica bianca delle viti incastrate nella copertura inferiore vicino alla parte anteriore della Wii.
    Die Abdeckungen sind geklebt, stecken also nicht.
    Ludger - Replica
    Don’t mistakenly remove the rubber case feet
    Bob Trout - Replica
    I just did. That picture could be better.
    B G -
    Thanks I almost removed the rubber feet
    Lushane - Replica
    If you’re wondering what to use for this, the main blade of a pocket knife from the corner of the plastic works well.
    Cameron Holman - Replica
    As you remove the hardware in each step, place them together on a sheet of paper and circle them with the step number.
    Tom J - Replica
    Very helpful suggestion, thanks!
    Christopher Reese -
    Caution: Before you begin disassembly. If possible, power on your Wii, and attempt to eject whatever disk you may have in the drive.
    Steve - Replica
    1:
    I'd recommend removing the RTC Battery before starting to completely remove all power. You can see how in step 15.
    2:
    When removing the screw covers I'd recommend inserting tweezers in the bottom corners facing away from the rubber feet.
    When the tweezers are inserted you should push them down to grab on to the cover and pull it off.
    Macro Man - Replica
  2. Sostituzione lente lettore DVD Nintendo Wii: passo 2, immagine 1 di 1
    • Svita le due viti Tri-Point da 8,3 mm nascoste sotto le coperture appena rimosse.
    Before you start, get a small plastic tray with at least 15 small bins in it, and put the screws you take out in each step in the bins in order. It makes reassembly a LOT easier.
    larry - Replica
    NOTE: You need a Y1 screwdriver. Be careful when buying the little red screwdrivers on Amazon that claim to fit the Wii - they don’t!! From personal experience.
    Robotai - Replica
    I have an ifixit kit and the Y1 didn't fit. I ended up using a Y0 and it worked.
    Macro Man -
    Just to add to Robotai’s comment, if you do get the little red/orange screwdrivers on Amazon, file off the tip. It if’s mostly blunt, it fits the tri-wing screws much better.
    jeff - Replica
    1/16 x 1 craftsman Phillips mini screwdriver works for this if you don’t have the tri-wing driver
    grace nicosin - Replica
    How do you make one ? If you don’t have the screwdriver
    Ethan - Replica
    I am using a 18ct empty egg carton to hold the screws/parts removed in the steps.
    karenmparamore - Replica
    Larry’s idea about the bins was great and helpful.
    Robots is right- you NEED a Y1. Just buy the thing with the drive. I didn’t, tried many other options, none worked. Had to order the thing separately with shipping. Mistake….
    David Ryan - Replica
    My two screws hidden are on the backend of the Wii. This picture shows them on the front.
    Leah Wendleton - Replica
    I had to hold the tri point driver in a vice-grip to get the leverage to get these screws out
    Bob Schwarz - Replica
    These screws were really tough for me too. Amazon screw driver was stripping them. I attached a 7 mm socket to the end of the screwdriver and got enough force to get them out.
    NateB - Replica
  3. Sostituzione lente lettore DVD Nintendo Wii: passo 3, immagine 1 di 1
    • Svita la vite a croce Phillips da 5,9 mm sotto la porta delle prese dei controller vicino alla copertura anteriore.
    Pry the square rubber piece in the middle, not the hard plastic square frame.
    David Will - Replica
  4. Sostituzione lente lettore DVD Nintendo Wii: passo 4, immagine 1 di 1
    • Usa uno spudger in metallo per rimuovere il piedino in gomma incastrato sul lato della Wii vicino all'ingresso del lettore DVD.
    All of the rubber feet on my very old Wii had literally melted into a gooey mess and just needed to be scraper off and cleaned with alcohol.
    Bob Robins - Replica
  5. Sostituzione lente lettore DVD Nintendo Wii: passo 5, immagine 1 di 1
    • Svita la vite a croce Phillips da 5,9 mm nascosta sotto il piedino appena rimosso.
    please help! my lil sis got a disc stuck in my wii while it was off!!! please help fast!!!
    Leah Vegan - Replica
    does it turn on?
    Giovanni Munoz - Replica
    It won’t come out, it will turn and go up but it won’t go fully out
    Mmbb - Replica
  6. Sostituzione lente lettore DVD Nintendo Wii: passo 6, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Tira via delicatamente la copertura anteriore dalla Wii.
    • Usa un paio di pinzette per scollegare il connettore in plastica del cavo dei LED dalla scheda madre.
    • Rimuovi la copertura anteriore.
    surprisingly, this was the trickiest step for me. I almost completely mangled the wires when my tweezers slipped as I was attempting to remove the connector.
    rbelknap - Replica
    I removed it with a spudger, gently lift from each side until it pops out.
    For those reassembling
    line up the pins push it in with your spudger gently until it's in. Then line up the front plate, push gently, confirm everything is where it should be and push firmly, I found it needed a strong push to sit flush with the other body panels.
    James middleton -
    I ended up using needle nose pliars on this step.
    Awesome detailed guide made this very easy, thank you author!
    Glenn Woodard - Replica
    Can someone direct me to what I need to do? My tweezers slipped and I cut one of the wires on the connector. Where can I find a new Y plug for the wii?
    jaredslaweski - Replica
    I also broke my wire trying to use tweezers. I should have known better. I use (normally do) a spudger on one side and my fingernail on the other to gently pry these types of connectors out. I ended up buying a replacement faceplate on ebay.
    Tyler - Replica
    This was the hardest part for me. I tried using my fingernails, two different tweezers, and needle nose pliers, but I ended up cutting both the wires. Anyway, I put some electric tape over the exposed wires and just reassembled the system. Funny thing is that the LED still works and I have not noticed any difference. I'm not sure what those wires did, but they seem to not be important.
    Nick - Replica
    For people still wondering after all these years, :), The connector is for the blue leds around the dvd when loading and unloading a disk.
    Niels -
    I also broke off the flimsy wires at the connector. To NOT break the wires, alternate pressing on the right and left sides of the connector with a small flathead screwdriver. Be patient, it will eventually work itself free. There isn't enough to grab onto with the tweezers and you'll only succeed in having them slip off, grab the wires, and yank the wires out.
    Good news is that if you do rip out the wires, no worries... I didn't reconnect them and the unit works just fine. I have no idea what those wires are even for. Power LED continues to work no problem.
    jasendorf - Replica
    I used two small flat head screw drivers, one on each side to pry out the connector. This created less pressure from me and reduced my chance of cutting the wires.
    mulkey - Replica
    This guide is really marvellous - works a treat. But I would definitely recommend needle nose pliers for this step rather than tweezers. It's really easy if you use pliers and potentially damaging if not, and you get it wrong. I had one sniff at it with tweezers then immediate nipped out to the garage for my pliers!
    thepitcanary - Replica
    Definitely a tricky step with that connector. I also cut broke the wire accidentally and was going to just give up trying to fix the Wii. However, as others stated the Wii works just fine, including the lights. I do wonder what those wire are for.
    darcaesar - Replica
    I also had a lot of trouble trying to get the connector off with tweezers. Ended up leaving it attached. It does not really get in the way of remaining steps.
    Ron Even - Replica
    Needlenose pliers did the trick for us!
    Ron Cormier - Replica
    Needlenose pliers did it for us!
    You can save yourself some trouble at this point and skip the rest of the disassembly: See that green tab to the left of the sd card slot? THAT’S the wifi board (and that green tab, in hindsight, seems designed to make it accessible without taking apart the whole device, don’t you think?) A little careful spudging, and you’ve got it out, ready to replace! (There’s a guy who shows the process on youtube, if you want to review first)
    Will - Replica
    I got the connector out ok thanks to the suggestions here, but I couldn’t figure out how to reattach it. In the end, I just kind of threw it in and it worked fine.
    Christine Wittmer - Replica
    Very clear instructions - thanks! Faceplate needed replacing after one of my son’s friends accidentally kicked it across the room. $10 bucks to fix, thanks to ebay and these instructions. I’d never heard of a “tri-wing” screw before.
    LInda Rawlins - Replica
    I just left the connector alone and kept it connected while working on it. There is enough wire to allow you to do what you need if you are just careful not to snag it on anything.
    Michael Payne - Replica
    I, too, left the connector attached and just took care that the loose faceplate did not stretch the (not crucial) wire when moving rest of the Wii.
    Matti Haveri -
    This was the trickiest part, I almost broke the wires using tweezers and pliers, so instead use a flat end screwdriver to pry it out, when putting it back in use needlenose pliers to start it then use your fingernail to go the rest of the way.
    After I got the connector out I noticed the little locking flap on the top side of the connector. I think prying this first is the key to easier removal.
    Will B - Replica
    Anyone know of a method to replace the connector if you end up breaking the wires? Bits of wire are stuck in the white plastic connector, so I'm wondering if I can buy a connector online somewhere without replacing the whole face plate. Thanks :)
    Bronze Owl - Replica
    I severed both wires. If you want to avoid removing the connector, you can lengthen the two wires by unserpentining them from the wire holder that's in the cover.
    Griff Derryberry - Replica
    Make sure there is no SD card in your unit before pulling this off, otherwise it'll get stuck and you could snap your sd card in half!
    carlosahiciano - Replica
  7. Sostituzione lente lettore DVD Nintendo Wii, Copertura esterna: passo 7, immagine 1 di 3 Sostituzione lente lettore DVD Nintendo Wii, Copertura esterna: passo 7, immagine 2 di 3 Sostituzione lente lettore DVD Nintendo Wii, Copertura esterna: passo 7, immagine 3 di 3
    • Apri la porta protettiva delle prese dei controller finché è perpendicolare con la cornice nera delle prese.
    • Tira verso l'alto la porta protettiva per separarla dalla copertura esterna.
    • Ripeti questa procedura per la porta protettiva della scheda di memoria.
    I wasn't able to reassemble the socket covers when I reversed this step..
    While disassembling, I did as instructed pulling the covers upwards when they where perpendicular to the black cover plate but Nintendos instructions says to open the covers (so that they are perpendicular to the black cover plate) and then gently push the covers towards the console with your fingers on the outside of the cover opposite side of the hinges so that the cover hinges will pop out and then lift it up..
    I'm not sure, but I think ignoring Nintendos instructions caused the hinge sockets to break for me, so replacing the controller/memory card socket covers will not work.
    When reassembling, the cover can be placed perpendicular to the black cover plate and rest on the plastic hinge with a few millimeters between the cover and the console, and then they can be pushed down to click in place. But in my case they keep falling all the way down since there's no resistance and nothing to click into.
    Martin Johansson - Replica
  8. Sostituzione lente lettore DVD Nintendo Wii: passo 8, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 8, immagine 2 di 2
    • Svita le due viti a croce Phillips da 4,1 mm rimanenti sul bordo superiore della cornice in plastica nera delle prese dei controller.
    • Solleva la cornice dal bordo lungo più lontano dalle prese dei controller e rimuovila dalla Wii.
    The 3rd hole is in step 3.
    James middleton - Replica
    The bezel is the flat black plate. Removing the three screws that secure it allows you to remove it. If your cube is like mine, this plate likes where it lives and, even with the screws removed, managed to stay in situ without anything holding it.
    Dennis Johnston - Replica
    Beware. The edge of the bezel, opposite these screws, has clips. Lift the bezel from the top edge, where the the screws are, to avoid breaking these clips.
  9. Sostituzione lente lettore DVD Nintendo Wii: passo 9, immagine 1 di 1
    • Svita le due viti a croce Phillips da 5 mm sopra le prese dei controller.
  10. Sostituzione lente lettore DVD Nintendo Wii: passo 10, immagine 1 di 1
    • Usa uno spudger in metallo per rimuovere le tre coperture evidenziate delle viti incastrate sul lato della Wii.
  11. Sostituzione lente lettore DVD Nintendo Wii: passo 11, immagine 1 di 1
    • Svita le seguenti viti:
    • Due viti a croce Phillips da 5 mm
    • Una vite Tri-Point da 8,2 mm
    Instead of the Phillips screw on the left I had a very small one under a cover to the left of that!
    Donna Vought - Replica
  12. Sostituzione lente lettore DVD Nintendo Wii: passo 12, immagine 1 di 1
    • Usa uno spudger in metallo per rimuovere i due piedini in gomma incastrati sulla faccia inferiore della Wii vicino alle prese posteriori.
  13. Sostituzione lente lettore DVD Nintendo Wii: passo 13, immagine 1 di 1
    • Rimuovi le due viti Tri-Point da 8,2 mm nascoste sotto i piedini appena rimossi.
    • Puoi utilizzare un cacciavite esagonale da 4 mm per estendere la punta all'interno delle rientranze e raggiungere le viti.
    had a little trouble with theses screws. they were just barely too deep for my 54pies bit driver kit to reach. I ended up inserting a small wad of paper into the shaft of my driver so the tri-wing bit stuck out far enough to engage the screw. (I used the tweezers to remove the paper when I was done) :)
    rbelknap - Replica
    I can confirm, this works fantasticly!
    Thank you
    James middleton -
    When putting the screws back in hold the tip still with the screw and carefully drop it in.
    James middleton -
    When i tried it didn't work. But i did get it to work with blu tack instead as it holds better. It was alot harder to remove though.
    Macro Man -
    Thank you rbelknap, this is excellent advice for those using the ifixit branded driver.
    George Squires - Replica
    You could also use the 4mm nut driver in the iFixit kit to turn the tri-wing driver. This will give you a little more reach.
    Edward Tucker - Replica
    How is no one talking about the included 4mm nut driver trick at Edward Tucker mentioned?! That is genius! Thanks mate!
    Zabuza -
    That's the idea that I needed. Agree with Zabuza.
    cwdick -
    Bingo. All of the other comments were unnecessary.
    Tony Shannon -
    Because it doesn't come with the screw driver in the kit. Only has the tri wing and the cross tips.
    Craig Goodsell -
    This paper wad trick totally worked for me too!
    anonymous 779 - Replica
    Standard Tri-Wing bits will NOT fit into the holes. Make sure that you get one of the tool kits from iFixit (I just ordered the Mako Driver/Bit kit with 64 bits ) - the Tri-Wing bits in this kit have a narrow shaft that allows it to reach deep into narrow holes like these on the Wii . (Disclaimer - I have no association with iFixit).
    dave whale - Replica
    I just sawed off a bit of the shank holder from the iFixit tool, in order for the bit to go deep enough into the case.
    The tool still works fine.
    Alan Walker - Replica
    Thanks for the paper wad trick advice! Worked perfectly with my Wii
    Finder352 - Replica
    The 4mm driver was the exact fix for this problem, no mods necessary
    Tony Shannon - Replica
    I just realized that my ifixit kit never came with the 4mm driver! Instead they sent me two 3.5mm ones.
    gawift - Replica
    put a little gorilla tap around the shaft of the driver, that was the trick for me to get it to reach down
    SmokeyBare - Replica
  14. Sostituzione lente lettore DVD Nintendo Wii: passo 14, immagine 1 di 1
    • Solleva la copertura esterna dal corpo della Wii.
    This step could use at least another picture from the backside so it's clearer what comes up and what stays down.
    Jose Vazquez - Replica
    I used a spudger around the edges of the outer case to gently ease it upward since I could not lift it out with my fingers. Then it came right out.
    Marko - Replica
    Good tip. Having, in the past, broken pieces that required a little persuasion, I attempted to "lift" the outer case, but it wouldn't budge. Using the spudger to persuade it worked like a charm. Also added this suggestion to Step 18 "Lift the drive shield."
    Dennis Johnston -
    hey marko that really helped me thanks\. als if you need help figuring which side is up, its the one with the nintendo engraving on it
    Aryan Garg - Replica
    A fan filter fell out at this step how do you put it back?
    Edit: I figured it out it was from the side intake vent. Just line up the two notches with the pegs in the case to hold it in place
    Darren Jones - Replica
    This is an awful guide
    Alexander D Schaefer - Replica
    Yeah. I don't know why most of the official ifixit guides suck.
    Macro Man -
  15. Sostituzione lente lettore DVD Nintendo Wii, Lettore DVD: passo 15, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii, Lettore DVD: passo 15, immagine 2 di 2
    • Svita la piccola vite a croce Phillips che fissa la porta della batteria alla copertura inferiore.
    • Questa vite resterà ancorata alla porta della batteria.
    • Sfila la porta della batteria dalla Wii.
    • Il sistema si resetterà una volta che rimuovi la porta della batteria.
    • Questo è un buon momento per cambiare la batteria CR2032 se non lo hai fatto di recente.
    The screw on the battery door of my Wii required a Phillips #000 screwdriver, which is not listed in the required tools.
    Ben - Replica
    The screw is a PH0000 (quadruple zero) requiring an exceptionally small Phillips screwdriver to remove. If this is your first time in here in a while, this may also be a great time to change the CR2032 battery.
    Steve Bonds - Replica
    I was able to use the ph0 no problem.
    Darren Jones -
    I used a 00 with no problem.
    julie -
    What does this battery do? I never knew there was a battery inside of the WIi.
    Stephen Thornhill - Replica
    thje battery is used to maintain timwe and date etc
    Electronik -
    Where can we get a new battery from?
    Chriul Rg - Replica
    You can get a CR2032 batterie in your local supermarkt. It is recommended to change it after 5 years, but I have seen devices run for 15+ years.
    Playa -
    my wii survived 15 years already with the same battery
    Bas Molendijk - Replica
    I tried using a PH000, PH00, and PH0 screwdriver to no avail. I tried searching online for a PH0000 bit or screwdriver, and can't find anything. How can I unscrew this without stripping the screw or buying a PH0000 bit/screwdriver?
    Keiran Haas - Replica
    0000 bits are hard to come by, but you shouldn't need one. Is yours stuck on? Is it stripped at all?
    Isak -
  16. Sostituzione lente lettore DVD Nintendo Wii: passo 16, immagine 1 di 1
    • Svita la vite Tri-Point da 8,2 mm nascosta sotto la porta della batteria.
    Note - this screw is a machine screw (e.g. not self-tapping). It screws into a hex nut, and that nut is captive in a slot in the case. When reassembling, ensure that this hex nut is still captive, and has not migrated out to other areas within the Wii.
    dyanetti - Replica
    The other drive cage hole is screwed in step 11, continue to reassemble.
  17. Sostituzione lente lettore DVD Nintendo Wii: passo 17, immagine 1 di 1
    • Svita le due viti Tri-Point da 8,2 mm che tengono ferma la schermatura del lettore DVD vicino alle porte dei controller.
    The screw on the right for my wii just refuses to come out
    Robert Menocal - Replica
    I put my 3point driver in a vise grip to get the leverage on the screws
  18. Sostituzione lente lettore DVD Nintendo Wii: passo 18, immagine 1 di 1
    • Solleva la schermatura del lettore DVD e rimuovila dalla Wii.
    Be careful not to cut your fingers on the sharp edges of this metal shield. My daughter actually scraped enough skin to cause blood to drip off her finger. Then we noticed her skin stuck to the metal edge. Yuk.
    J Smith - Replica
    True story I did it to myself lol
    James middleton -
    Does the dvd shield need to be there? I want to remove it but im not sure if i should
    Kadamo - Replica
    If the drive shield needs a little extra persuasion, us a spudger around its perimeter. Also helps prevent cuts when force meets resistance on this metal shield.
    There are spring steel tabs on both sides.
  19. Sostituzione lente lettore DVD Nintendo Wii: passo 19, immagine 1 di 1
    • Svita le quattro viti a croce Phillips #1 da 9 mm che fissano il lettore DVD alla copertura inferiore.
    The two left hand screws were very difficult to relocate during reassembly. I was coaching my 8 year old through this, and this was probably the only step that he couldn't do. We dropped these screws several times, and used magnets to retrieve. Miniature needle-nose pliers gripping the 'washer' surface of the screw were too wide. We managed to purchase the 'button head' of these screws with the needle-nose and drop the screws into their hole, and push with the phillips until secure. I would like to hear how others install these screws, please.
    dyanetti - Replica
    I had the same problem as you and eventually found an easy way round it. I wrote this to be added to the instructions but it was rejected: "Once the DVD drive has been removed, remove the 4 rubber washers from the screws removed earlier and insert them into your new DVD drive. Because two of the screws are difficult to reach, it is best to insert these two screws into the washers and then slide them into place ready for securing to the base plate".
    The rubber washer holds the two screws roughly in position, you can then reach them with your screwdriver through the two holes (about an inch away) and finish tightening them up.
    Gary -
    For the two screws at the front of the chassis, use a three-pronged parts retriever to lift them out after you unscrew them.
    Walter - Replica
    Helpful tip: Use a magnetized screwdriver for the 2 screws nearest the DVD face because they are set in deep sockets
    Blake Minghelli - Replica
    During reassembly, it can be tricky to position the recessed screws. To temporarily magnetize your screwdriver, rub the tip against a magnet for 5-10 seconds. (A refrigerator magnet will do.) You should then be able to put the screw on the tip and gently lower it into position.
    Matt D - Replica
    Thanks - the refrigerator magnet trick worked for me,
    Jim Allen -
    Another method for getting the front screws back in is to insert a small pair of tweezers through the DVD slot to guide the screw in. I just dropped the screw in between the tweezers which held the screw just above the hole. Then I was able to use the phillips screwdriver to guide the screw into the hole and screw it in. Done in just a few seconds.
    Another option would be to stick a dab of hot glue on the screw to your screwdriver and then when the screw has been driven home either the glue stays on the driver and is easily removed or it stays on the screw and you just pull it off with tweezers or needle nose pliers.
    accts4mjs - Replica
    The screwdriver provided in the kit by ifixit is a magnetized screwdriver and works perfectly!
    mulkey - Replica
    If you are disassembling your Wii because, say, a two-year-old has shovelled pennies into it (yes, that was me) you will also need to partially disassemble the drive itself, which is not covered in this guide. Luckily it's really easy. Unscrew the 4-5 larger Philips/cross head screws on the top of the frame (NOT any of the smaller darker ones) around the edges, and the frame on top of the drive will lift right off. Be careful as there is cabling running to it, so don't yank it or pull it too far off. You will now be able to get any coins or other foreign objects out.
    I didn't have a magnetic screwdriver, so I applied a tiny amount of fabric glue to the head of each screw, waited a minute for it to start to harden, inserted my non-mag screwdriver into the screw head, and the screw stuck to the screwdriver long enough to insert it into the hole.
    Lee Crooks - Replica
    Be advised that the posts that these screws go into are very fragile and may even break. Make sure to get the little plastic pieces out if you over tighten them or they are just brittle and broken to begin with. The screws seem to be long enough to work if you do break the posts off completely.
    I needed a size 1 Phillips screwdriver for this step.
    julie - Replica
    Thanks, I will include it in the guide
    Angel -
    Be careful with these screws - they seem to be quite malleable and easy to strip.
    Electronik - Replica
    I ended up using an extra fine tweezers from a watch kit, stuck it through the vent opening "inside" the screw area and acted as guideposts to thread in. Only because I didn't have a magnet for the screw.
    kwjayhawk - Replica
    I guess this is a warning applicable to anything that has to do with plastics, but this step in particular: Be extra careful not to overtighten these screws when reassembling the unit because the plastic sockets will easily break/shatter..
  20. Sostituzione lente lettore DVD Nintendo Wii: passo 20, immagine 1 di 1
    • Solleva il bordo del lettore DVD opposto alle prese dei controller quanto basta per accedere ai cavi sulla faccia inferiore.
    • Tira attentamente il cavo di alimentazione del lettore DVD da sotto la copertura in plastica vicino al dissipatore.
    When reversing these steps to reassemble the Wii, at this point it is possible to do a quick test before screwing the drive to the case. This will save you a lot of time if something is wrong.
    Don't touch anything you don't have to while the case is off.
    Carefully plug the power cable into the back of the Wii, then use a screwdriver to gently press the white button next to the glowing yellow LED on the front. You should hear the DVD drive power up and whir. Then press the white button again, wait for the yellow light to come back, and unplug the Wii.
    If you didn't hear the drive start up, most likely one of the two ribbons isn't connected to the drive correctly. Doublecheck the previous 3 steps.
    Matt D - Replica
  21. Sostituzione lente lettore DVD Nintendo Wii: passo 21, immagine 1 di 1
    • Sfila il cavo di alimentazione del lettore DVD dalla sua presa sul lettore stesso.
    When reversing this step, be careful re-inserting the connector. The pins are very delicate and if you aren't at the proper angle, you can bend them and ruin the drive.
    jisakoff42 - Replica
    The exact thing happened to me just now; I reinserted it at a (very slight) angle, and bent one of the pins at the end of the socket. Luckily, I was able to straighten it back up with a sewing needle. I made sure the spacing was consistent with the rest of the pins, and that I reinserted the connector as straight as I could, so it doesn’t happen again.
    Jose Olarte III -
    Reinsterting the connection caused the connecter to fall of the print borad, even if I was very careful.
    On the orginal board, the connector is solid as a rock.
    Bjørn Johannesen - Replica
    1) The silver cable doesn’t need any force to insert - just push it gently in and use the retaining flap to lock it in place;
    2) The DVD drive power cable is a little tricky because of the orientation - take a look of the pins inside the socket: it is located more toward the outside surface (not in the middle). As such, check your cable orientation before insert, make sure it is in the right orientation such that the holes will meet the pins. It takes me one try to snug it in nicely.
  22. Sostituzione lente lettore DVD Nintendo Wii: passo 22, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 22, immagine 2 di 2
    • Usa le unghie per ruotare verso l'alto l'aletta di bloccaggio del connettore del cavo a nastro del lettore dischi.
    • Assicurati di agire sull'aletta di bloccaggio e non sul connettore.
    • Sfila il cavo a nastro del lettore dischi dalla sua presa.
    • Rimuovi il lettore dischi dalla Wii.
    When reversing this step, make sure the ribbon is all the way in. For some reason I found positioning it with my replacement drive was much harder than with my old drive. The gentlest tug after lowering the brown clip would show that the ribbon was not actually being held tightly. I thought for a while that the clip itself was broken, but eventually I got it to hold the ribbon correctly.
    Matt D - Replica
    Be careful with this step. I too had difficulty re-inserting the ribbon. I even popped off the brown clip and thought I broke it. Thankfully it snapped back into place.
    Dana Kennard - Replica
    It is difficult to tell, but be aware that the brown piece is the retaining flap, not the light piece , which is the actual socket.
    Dan Neunaber - Replica
    I had to use Kapton tape. I couldn’t get the clip back on.
    Jim Allen - Replica
    This was the trickiest step for me. Take note of how the ribbon is configured before you loosen the clip to help you replace it with confidence in the right way.
    Ping Wu - Replica
    Careful! When reinstalling, I think I bent and broke the ribbon. The Wii doesn't respond upon power up - I think because it doesn't see the drive.
    Steve Bennett - Replica
  23. Sostituzione lente lettore DVD Nintendo Wii, Lente lettore DVD: passo 23, immagine 1 di 1
    • Sfila il cavo a nastro del rilevatore dei dischi dalla sua presa con un paio di pinzette.
    If you’re doing a drive swap this step in not necessary.
    netdude21 - Replica
  24. Sostituzione lente lettore DVD Nintendo Wii: passo 24, immagine 1 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 24, immagine 2 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 24, immagine 3 di 3
    • Usa la punta di uno spudger per spingere verso l'esterno del connettore le sporgenze di bloccaggio sulla presa ZIF del cavo a nastro del motore mandrino.
    • Scollega il cavo a nastro del motore sfilandolo dalla sua presa con un paio di pinzette.
  25. Sostituzione lente lettore DVD Nintendo Wii: passo 25, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 25, immagine 2 di 2
    • Rimuovi il pezzo di nastro adesivo in tessuto nero che copre una parte del cavo a nastro della lente.
  26. Sostituzione lente lettore DVD Nintendo Wii: passo 26, immagine 1 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 26, immagine 2 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 26, immagine 3 di 3
    • Scollega il cavo a nastro della lente spingendo per prima cosa le due alette di bloccaggio del connettore ZIF verso il cavo stesso con la punta di uno spudger.
    • Usa un paio di pinzette per sfilare il cavo a nastro della lente dalla sua presa.
    Re-assembly comment: After re-connecting the lens ribbon cable is a great time to remove the solder blob from the replacement lens.
    Tom - Replica
    My drive has a smaller board revision
    Jilvenhong Dickinson - Replica
  27. Sostituzione lente lettore DVD Nintendo Wii: passo 27, immagine 1 di 1
    • Svita le due viti a croce Phillips da 5,0 mm che fissano la scheda del lettore DVD alla copertura del lettore stesso.
  28. Sostituzione lente lettore DVD Nintendo Wii: passo 28, immagine 1 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 28, immagine 2 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 28, immagine 3 di 3
    • Solleva la scheda del lettore DVD dalla copertura del lettore sollevando il bordo del connettore del cavo a nastro della lente.
    • Tira il bordo opposto della scheda verso l'alto mentre la sollevi per liberarla dai piccoli ganci in plastica nera che la tengono ferma.
  29. Sostituzione lente lettore DVD Nintendo Wii: passo 29, immagine 1 di 1
    • Sfila i cavi saldati alla scheda del lettore DVD da sotto i ganci in plastica nera con la punta di uno spudger.
    I found it was easiest to unwind red and brown first and then white, blue, gray, yellow.
    Carol - Replica
    I found this was easiest one wire at a time
    Tom - Replica
  30. Sostituzione lente lettore DVD Nintendo Wii: passo 30, immagine 1 di 1
    • Appoggia la scheda del lettore DVD accanto al lettore stesso in modo che i cavi saldati alla scheda non ti intralcino (come mostrato nell'immagine).
    • Svita la vite a croce Phillips da 5,0 mm sulla schermatura EMI del lettore DVD.
  31. Sostituzione lente lettore DVD Nintendo Wii: passo 31, immagine 1 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 31, immagine 2 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 31, immagine 3 di 3
    • Il bordo della schermatura EMI con l'apertura per il cavo a nastro della lente ha due piccoli ganci in metallo che si fissano a delle linguette in plastica nera sulla copertura del lettore DVD.
    • Usa la punta di uno spudger per piegare i due ganci in metallo in modo che non facciano più presa sulle rispettive alette in plastica.
    • La schermatura EMI è fatta in un metallo morbido e pieghevole. Può essere facilmente deformata e quindi riportata nella forma originale, ma se fai troppa forza puoi rompere i ganci.
    • Assicurati che entrambi i ganci siano ripiegati nella posizione originale durante il rimontaggio.
  32. Sostituzione lente lettore DVD Nintendo Wii: passo 32, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 32, immagine 2 di 2
    • Le piccole alette sulla schermatura EMI sono infilate in due aperture sul bordo esterno della copertura del lettore DVD.
    • infila la punta di uno spudger nell'apertura più vicina ai cavi rosso e rosa che si collegano alla scheda del lettore DVD.
    • Ruota lo spudger per estrarre la prima aletta dalla sua apertura nella copertura del lettore.
    Regarding Step 32 and 33 - I did this a little differently, and didn't need to bend (plastic deformation) the tin. Complete Step 31, but instead of 'bending' the clips, you release them and pop the tin up over the plastic 'barb' to release the EMI shield. Then, then repeat Step 31 (popping the tin clips off of the barb) for the two tabs on the opposite side (screw side) of the EMI shield. The EMI shield can then be withdrawn, e.g. released to the bottom of the picture in steps 32 and 33, without bending the tin as advised in step 32 and 33. The only mildly tricky part was releasing the clip from the barb near the (blue/yellow/grey/white) wires connecting the laser stepping motor - I used a fine flat screwdriver.
    dyanetti - Replica
    Agree with dyanetti; the two end tabs in step 32-33 are not intended to be bent. Should release all four of the clips on the sides of the plate first, then it will rotate up and the end pins will just slide out (and in when reversing the process for reassembly).
    If you take the top off the dvd drive, these tabs are easy to unlatch from the other side.
    ChrisV - Replica
  33. Sostituzione lente lettore DVD Nintendo Wii: passo 33, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 33, immagine 2 di 2
    • Ripeti la procedura del passo precedente per rimuovere la seconda aletta della schermatura EMI dalla sua apertura nella copertura del lettore DVD.
    • Potrebbe essere necessario tenere fermo il bordo opposto della schermatura EMI per evitare che le alette si reinfilino nelle rispettive aperture.
  34. Sostituzione lente lettore DVD Nintendo Wii: passo 34, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 34, immagine 2 di 2
    • Prendi la schermatura EMI dai due bordi liberati e ruotala leggermente verso il bordo che è ancora bloccato finché gli ultimi due ganci si liberano.
    • Solleva la schermatura EMI dal lettore DVD.
  35. Sostituzione lente lettore DVD Nintendo Wii: passo 35, immagine 1 di 1
    • Svita la vite a croce Phillips da 5,0 mm più vicina ai cavi giallo, blu, bianco e grigio.
  36. Sostituzione lente lettore DVD Nintendo Wii: passo 36, immagine 1 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 36, immagine 2 di 3 Sostituzione lente lettore DVD Nintendo Wii: passo 36, immagine 3 di 3
    • Mentre tieni fermo il lettore DVD con una mano, afferra il perno di bloccaggio della lente del lettore (vicino alla vite appena rimossa) con delle pinzette a becchi sottili.
    • Fai scorrere il perno di bloccaggio verso il bordo della copertura del lettore.
    • Sfilare il perno richiede abbastanza forza, per poi diventare più facile.
    • Quando il perno si muove liberamente, prendilo con le dita e sfilalo completamente dalla copertura del lettore DVD.
    There is a small piece of black plastic next to the last screw which was removed. Lifting this up a millimeter or two will release the retaining pin so that it can be moved out easily.
    FRAC - Replica
    What to do when these Clips Break?
    Marco Bienert (RodneyMcKay) -
    It's important not to scratch this rod with the pliers. I would use fingertips or plastic tweezers for this step, or wrap the needlenose pliers with tape first.
    ChrisV - Replica
    Careful! It’s so easy to break that black plastic piece. Notice that it’s only connected at one end and hinges very easily causing a stress fracture. Whether you lift it from the side or go in through the end hole, minimize the number of times you hinge it.
    I found that vinyl tape-wrapped bent-nose pliers worked well to grip the rod.
    Brian - Replica
  37. Sostituzione lente lettore DVD Nintendo Wii: passo 37, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 37, immagine 2 di 2
    • Afferra il gruppo della lente del lettore DVD dal bordo del perno che hai appena rimosso.
    • Rimuovi il gruppo della lente dalla copertura del lettore.
  38. Sostituzione lente lettore DVD Nintendo Wii: passo 38, immagine 1 di 2 Sostituzione lente lettore DVD Nintendo Wii: passo 38, immagine 2 di 2
    • Svita la vite a croce Phillips da 4,2 mm fissa la staffa in plastica bianca al gruppo della lente.
    • Solleva la staffa dal gruppo della lente.
    • Se stai installando una nuova lente, assicurati di trasferire la staffa e la vite sulla lente nuova prima di installarla.
    May need an additional step when replacing with a new laser sled assembly: The new one will have a solder blob across two signals for esd protection; this must be removed after the new laser is installed, otherwise it will be completely unable to read the disk.
    ChrisV - Replica
    agree with Chris V you have to de-solder the solder dot on ribbon just make a straight vertical line compare it to the replacement laser this should be step 39 because if you don't do this the laser lens will not be able to read properly
    keytechllc - Replica
    Had the same issue. I wasted a couple hours troubleshooting the new laser before figuring out that I needed to de-solder the solder blob shorting the 2 signal lines.
    Christopher Daun - Replica
    Any tips on removing the screw from the white plastic bracket that needs to connect to the new part? It is not loosening on the old one at all. New mini-philips on order to see if they will fit better and hold but I don't think this is going to come free. Does anyone know where a new white plastic bracket can be ordered?
    eljuline - Replica
    Correctly sized philips was all it took. Came off right away. So all set to put it back together tonight.
    eljuline -
    Does the author cares about comments or not? The guide is missing one fundamental step that has been already pointed out by the comments from 4 years ago!!
    Marco Bo - Replica
    I too wasted time with this repair until I saw these comments. Completely reassembled, tested, then repeated the whole process again to check all the connections. When I finally found these comments I attempted to remove the solder but ended up with a flakey - partially working wii. I assume I damaged the ribbon cable in the process.
    Ultimately I spent another $20 and bought a new DVD unit ($5 more than the replacement lens) and has my wii working in 15 minutes. I wish I had seen these notes first - I wouldn’t have wasted my time trying to replace the lens. Please, please, please update this guide and save the community a lot of trouble!
    David Begleiter - Replica
    Does anyone know where too by white plastic bracket thing
    Hassan Farooqi - Replica
    Avant d'acheter une nouvelle lentille, essayer de nettoyer le ruban doré de la lentille ! Sur la mienne, la colle du scotch noire était collée dessus, et c'est ce qui empêchait la lecture des CD. Après nettoyage, ma Wii était comme neuve ! :)
    Julien Keller - Replica
Conclusione
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 140 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en it
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
David Hodson
Membro da: 04/13/10
152.757 Reputazione
127 Guide realizzate
25Commenti sulla guida
Many thanks for the excellent guide - my wii is working again!
Niel Viljoen - Replica
WOW! I have seen a lot of repair manuals and guides, and this has to be one of the best!
Appreciate the care and craftsmanship it took to put this together.
One suggestion: Please add pics of the screws with specs to compare the sizes.
Terry - Replica
very informative...if the laser is dirty or the lens is broken....will the tray from the drive come out and go inside...as normal ....please assist...
Techy - Replica
All went well. The main problem I had was tweezers of low quality. Also, during assembly, some screws was to tricky, so I needed to magnetize screwdriver and for that purpose I used - a speaker :)
Great tutorial, in deed. David just saved Christmas for me and my family.
Dragan - Replica
This is one of the best set of instructions I have ever used. Easy to follow steps with accurate illustrations. Very well done, I don't know how you could make it any better! A++,
camoore4800 - Replica
Me too. After solder blob removed, my Wii was able to read GameCube disks and most of my Wii disks.
debrota - Replica
Me too. After solder blob removed, my Wii was able to read my GameCube disks and most of my Wii disks.
debrota - Replica
Me too. After solder blob removed, my Wii was able to read my GameCube and most of my Wii disks.
debrota - Replica
Very useful and detailed.
John Rosenberger - Replica
Dare I try this on my own?
Simon Clark - Replica
Hola el lente de mi wii no intenta leer, al introducir un dvd el lente da un golpe y luego tres golpes mas, no suena como si intentara leer el disco, de echo tampoco se oye girar al disco, Quisiera saber si este problema es por el laser dañado o si se daño el motor que hace girar el dvd. Mi correo es david19_4@hotmail.com si pudiera ayudarme le agradeceria, puede responderme en ingles yo puedo traducirlo. Gracias
david19_4 - Replica
i tried this ix but as i was doing it i flipped the drive over and a small metal clip fell out and cant find where it has to go back in???
can anyone help please?
thanks in advance
dany - Replica
★☆★ Top Marks ★☆★ for a well thought out and fantastically illustrated procedure.
My 7 year old son and I worked as a team and it worked like a dream.
The only thing is, that we didn’t originally desolder the bridge on the new lens cable, so we had to work back through to step 22. However, this only took us 20 minutes extra :)
Many, many thanks to Mark and your 7 contributors. ★☆★ Nice Work ★☆★
Ted George - Replica
This is one of the most detail oriented tutorial I’ve ever seen. On Step 11, the screws were also color coded to avoid confusion. Great work!
I was able to follow this tutorial and replace the lens module with ease. The Wii system is now able to read the DVDs. Now, however, I have an issue. The Wii console is making a huge din after the replacement. Does anyone this issue? What do I need to do to fix the issue?
Thanks again for a great tutorial!
affansayed - Replica
How can I tell if my lens is broken and if it’s in a bad (reversible) condition?
John - Replica
My two year old stuck playing cards into the disc slot causing no disc to be read. I purchased the Apollo Precision Tool Kit for Phone and Computer Repair, it contained everything I needed to get the job done. I only had to complete through step 19 to push the cards out. Took about 2 hours to complete the project.
Noone Particular - Replica
This was a really good guide, I got my Wii working again and I am happy.
Sara Zielinski - Replica
Thank you so much!
John - Replica
Best disassembly instructions ever!!!
terry.huberts - Replica
Thanks for the great instructions, we had no problems getting our Wii working again!
Peter Krystad - Replica
nach einbau des neuen laser geht es immer nocht,immer noch die selbe fehlermeldung disk kann nicht gelesen werden
Marco Ott - Replica
This is an excellent guide. Thanks for putting it together!
Scott Carter - Replica
This was great, thanks! But I did have to look up elsewhere how to desolder the static point on the new laser assembly which I learned about in several videos I watched to get an idea of what I was getting into before I started.
Holly S - Replica
this is a lifesaver for my wii!
Cameron Smith - Replica
will try this when I get the materials that I need. But so far, this looks pretty promising.
Andrew Burley - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 33
Ultimi 7 Giorni: 246
Ultimi 30 Giorni: 1,046
Tutti i Tempi: 198,600
