Salta al contenuto principale
Sophix TAB-730g Battery Replacement
Cosa ti serve
  1. Sophix TAB-730g Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the back cover to gain access to the mother board.
    • Unscrew, with a 000 Philip's screwdriver, the 3.547 mm long screw located at the bottom of your tablet.
  2. Sophix TAB-730g Battery Replacement: passo 2, immagine 1 di 1
    • Firmly slide the cover in the direction indicated by the arrow, away from the ports, with your hand to remove the back cover.
  3. Sophix TAB-730g Battery Replacement: passo 3, immagine 1 di 1
    • Desolder the two wires connecting the battery to the mother board.
  4. Sophix TAB-730g Battery Replacement: passo 4, immagine 1 di 1
    • Gently pry the battery off the back of the device using some force.
    • There is adhesive keeping the battery attached so a decent amount of force may need to be applied.
Conclusione
Altre 2 persone hanno completato questa guida.
JT Hiquet
Membro da: 09/29/16
333 Reputazione
3 Guide realizzate
IUPUI, Team 2-3, Harley Fall 2016 Membro di IUPUI, Team 2-3, Harley Fall 2016
IUPUI-HARLEY-F16S2G3
4 Membri
6 Guide realizzate
Un commento
[|how do you know if the problem is or is not the battery?]
Don Taylor - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 380
