Salta al contenuto principale
Sony Xperia Z1 - Password Removal, Firmware update with PC Companion
Panoramica Video
  1. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 1, immagine 1 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 1, immagine 2 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion, Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 1, immagine 3 di 3
  2. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 2, immagine 1 di 2 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 2, immagine 2 di 2
    • Insert wisdom here.
  3. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 3, immagine 1 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 3, immagine 2 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 3, immagine 3 di 3
    • From here you can update your device firmware but it must be unlocked (device can't be in lock screen).
    • Start the new PC Companion function "Support Zone".
    • PC Companion will download some necessary files and you are ready to start "Phone / Tablet Software Update".
  4. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 4, immagine 1 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 4, immagine 2 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 4, immagine 3 di 3
    • Your laptop must be connected to the power adapter.
    • Select "repair my phone / tablet".
    • The last warning for your personal data
  5. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 5, immagine 1 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 5, immagine 2 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 5, immagine 3 di 3
    • After PC Companion prepared your laptop for the update, you must choose the model of your device.
    • The battery must be at last 80% charged.
    • Doesn't make a mistake in choosing the model.
  6. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 6, immagine 1 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 6, immagine 2 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 6, immagine 3 di 3
    • Switch of the phone. If you have a problem with the Android OS and you can't switch it off, then press and hold the power on button for a long time, or use the reset button under the micro SIM cover.
    • Press and hold the volume down button and then insert the micro USB cable.
    • Your PC will recognize the phone and PC Companion will download the latest version for your device and will flash it.
  7. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 7, immagine 1 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 7, immagine 2 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 7, immagine 3 di 3
    • If your PC doesn't recognize you phone (SOMC Flash Device), you must install drivers for it.
    • S1Boot Fasboot drivers
  8. Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 8, immagine 1 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 8, immagine 2 di 3 Sony Xperia Z1  - Password Removal, Firmware update with PC Companion: passo 8, immagine 3 di 3
    • When PC Companion finished updating, disconnect the phone and switch it on.
    • Your device is with latest firmware, in factory state, without personal data and security.
    • Please SUBSCRIBE to my channel ツ
Conclusione
Altre 19 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.308 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.535 Guide realizzate
3 Commenti
Thank you, this was really helpful.
DOWNLOAD AND UPDATE FIRMWARE SONY XPERIA XZ 601SO gofirmware
Jacky888 Jacky888 - Replica
Great platform to unlock my device.
get Offline Freeware Software’s
Offline Freewarefiles - Replica
which version is it? sony companion doesnt let you do it in latest. plz reply
DcKnown by Public - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 21,093
