Salta al contenuto principale
Sony Xperia XA2 Ultra LCD Screen Replacement
Cosa ti serve
  1. Sony Xperia XA2 Ultra LCD Screen Replacement, Rear Cover: passo 1, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement, Rear Cover: passo 1, immagine 2 di 2
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 2, immagine 1 di 1
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 3, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 3, immagine 2 di 2
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 4, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 4, immagine 2 di 2
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 5, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 5, immagine 2 di 2
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 6, immagine 1 di 1
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra LCD Screen Replacement, Motherboard Bracket: passo 7, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement, Motherboard Bracket: passo 7, immagine 2 di 2
    • Remove the six 3 mm Phillips #000 screws.
  8. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 8, immagine 1 di 1
    • Remove the motherboard bracket with an iFixit opening tool.
  9. Sony Xperia XA2 Ultra LCD Screen Replacement, Headphone Jack: passo 9, immagine 1 di 1
    • Remove the single 3 mm screw using a Phillips #000 screwdriver.
  10. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 10, immagine 1 di 1
    • Use the Jimmy to pry and remove the headphone jack.
  11. Sony Xperia XA2 Ultra LCD Screen Replacement, Speaker: passo 11, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement, Speaker: passo 11, immagine 2 di 2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  12. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 12, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 12, immagine 2 di 2
    • Using an iFixit opening tool, pry and remove the speaker.
  13. Sony Xperia XA2 Ultra LCD Screen Replacement, Charging Port: passo 13, immagine 1 di 1
    • Using the iFixit opening tool, disconnect the flex cable.
  14. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 14, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 14, immagine 2 di 2
    • Remove both the black and white antenna cables using the Jimmy.
  15. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 15, immagine 1 di 1
    • Remove the vibration flex cable with the Jimmy.
  16. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 16, immagine 1 di 1
    • Using the Jimmy and the iFixit opening tool, remove the charging port.
  17. Sony Xperia XA2 Ultra LCD Screen Replacement, Vibration Motor: passo 17, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement, Vibration Motor: passo 17, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using the tweezers, pry underneath the vibration motor and pull from its place.
    • There is an adhesive underneath it so removing it may take a bit of work.
  18. Sony Xperia XA2 Ultra LCD Screen Replacement, Motherboard: passo 18, immagine 1 di 1
    • Using the Jimmy, remove the two antenna flex cables.
  19. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 19, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 19, immagine 2 di 2
    • Using the iFixit opening tool, pry and remove the motherboard.
  20. Sony Xperia XA2 Ultra LCD Screen Replacement, Cameras: passo 20, immagine 1 di 1
    Compra
    • Use a pair of tweezers to remove the rear-facing camera.
    • Use a pair of tweezers to remove the magnetic tape covering the front-facing camera.
    • Use a pair of tweezers to remove the front-facing camera.
  21. Sony Xperia XA2 Ultra LCD Screen Replacement, Battery: passo 21, immagine 1 di 1
    Compra
    • Grab and twist the black battery tab with a pair of precision tweezers.
    • This will remove the adhesive that is attached to the battery.
    • Do this again with the black tab under the power button flex cable.
  22. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 22, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 22, immagine 2 di 2
    • With the iFixit opening tool, remove the battery.
  23. Sony Xperia XA2 Ultra LCD Screen Replacement, LCD Screen: passo 23, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement, LCD Screen: passo 23, immagine 2 di 2
    • Remove the black and white flex antenna cables by hand.
  24. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 24, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 24, immagine 2 di 2
    • Remove the six 3 mm T5 Torx screws.
    • The sides of the phone should fall off once the screws are out.
  25. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 25, immagine 1 di 1
    • Pull up the flex tape so it is loose.
  26. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 26, immagine 1 di 2 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 26, immagine 2 di 2
    • With your heat gun, heat the edges of the phone for about a minute. Using the iFixit opening picks, pry underneath the screen.
    • If you are having trouble, the iFixit opening tool may help gain leverage.
  27. Sony Xperia XA2 Ultra LCD Screen Replacement: passo 27, immagine 1 di 3 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 27, immagine 2 di 3 Sony Xperia XA2 Ultra LCD Screen Replacement: passo 27, immagine 3 di 3
    • Take the picks and run them around the screen, removing the screen from the adhesive.
    • Slowly lift and remove the screen.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 31
Tutti i Tempi: 491
