Salta al contenuto principale
Sony Xperia XA1 Speaker Replacement
Cosa ti serve
  1. Sony Xperia XA1 Speaker Replacement, Phone Back Cover: passo 1, immagine 1 di 3 Sony Xperia XA1 Speaker Replacement, Phone Back Cover: passo 1, immagine 2 di 3 Sony Xperia XA1 Speaker Replacement, Phone Back Cover: passo 1, immagine 3 di 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Speaker Replacement, Speaker: passo 2, immagine 1 di 3 Sony Xperia XA1 Speaker Replacement, Speaker: passo 2, immagine 2 di 3 Sony Xperia XA1 Speaker Replacement, Speaker: passo 2, immagine 3 di 3
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
  3. Sony Xperia XA1 Speaker Replacement: passo 3, immagine 1 di 3 Sony Xperia XA1 Speaker Replacement: passo 3, immagine 2 di 3 Sony Xperia XA1 Speaker Replacement: passo 3, immagine 3 di 3
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
  4. Sony Xperia XA1 Speaker Replacement: passo 4, immagine 1 di 2 Sony Xperia XA1 Speaker Replacement: passo 4, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
  5. Sony Xperia XA1 Speaker Replacement: passo 5, immagine 1 di 3 Sony Xperia XA1 Speaker Replacement: passo 5, immagine 2 di 3 Sony Xperia XA1 Speaker Replacement: passo 5, immagine 3 di 3
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
Conclusione
Hunter
Membro da: 02/14/23
349 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 8
Tutti i Tempi: 115
