Salta al contenuto principale
Sony Xperia XA1 Audio Jack Replacement
Cosa ti serve
  1. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: passo 1, immagine 1 di 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: passo 1, immagine 2 di 3 Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: passo 1, immagine 3 di 3
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: passo 2, immagine 1 di 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: passo 2, immagine 2 di 3 Sony Xperia XA1 Audio Jack Replacement, Audio Jack: passo 2, immagine 3 di 3
    • Use a Phillips #000 Screwdriver to remove the three 3 mm screws from the top bracket.
  3. Sony Xperia XA1 Audio Jack Replacement: passo 3, immagine 1 di 3 Sony Xperia XA1 Audio Jack Replacement: passo 3, immagine 2 di 3 Sony Xperia XA1 Audio Jack Replacement: passo 3, immagine 3 di 3
    • Use a spudger to gently pry the three tabs at the top of the phone and release the camera cover.
    • Gently lift the cover.
  4. Sony Xperia XA1 Audio Jack Replacement: passo 4, immagine 1 di 3 Sony Xperia XA1 Audio Jack Replacement: passo 4, immagine 2 di 3 Sony Xperia XA1 Audio Jack Replacement: passo 4, immagine 3 di 3
    • Use the Phillips #000 Screwdriver to remove the 3 mm screw to the left of the audio jack component.
    • Use an opening tool to lift the audio jack connector.
    • Pinch the connector and remove the audio jack.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 132
