Salta al contenuto principale
Sony XAV-AX100 Display Board Replacement
Cosa ti serve
  1. Sony XAV-AX100 Display Board Replacement, USB Cable: passo 1, immagine 1 di 3 Sony XAV-AX100 Display Board Replacement, USB Cable: passo 1, immagine 2 di 3 Sony XAV-AX100 Display Board Replacement, USB Cable: passo 1, immagine 3 di 3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Display Board Replacement: passo 2, immagine 1 di 2 Sony XAV-AX100 Display Board Replacement: passo 2, immagine 2 di 2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Display Board Replacement: passo 3, immagine 1 di 1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Display Board Replacement: passo 4, immagine 1 di 1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Display Board Replacement: passo 5, immagine 1 di 3 Sony XAV-AX100 Display Board Replacement: passo 5, immagine 2 di 3 Sony XAV-AX100 Display Board Replacement: passo 5, immagine 3 di 3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
    Our radio is not interfacing with my phone it says USB connection problem before I tear it all apart what else could it be thank you
    Don Bartolotta - Replica
  6. Sony XAV-AX100 Display Board Replacement, Motherboard: passo 6, immagine 1 di 2 Sony XAV-AX100 Display Board Replacement, Motherboard: passo 6, immagine 2 di 2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Display Board Replacement: passo 7, immagine 1 di 3 Sony XAV-AX100 Display Board Replacement: passo 7, immagine 2 di 3 Sony XAV-AX100 Display Board Replacement: passo 7, immagine 3 di 3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Display Board Replacement, Display: passo 8, immagine 1 di 1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Display Board Replacement: passo 9, immagine 1 di 2 Sony XAV-AX100 Display Board Replacement: passo 9, immagine 2 di 2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
  10. Sony XAV-AX100 Display Board Replacement, Display Board: passo 10, immagine 1 di 3 Sony XAV-AX100 Display Board Replacement, Display Board: passo 10, immagine 2 di 3 Sony XAV-AX100 Display Board Replacement, Display Board: passo 10, immagine 3 di 3
    • Remove the four 3.5mm Phillips #0 screws from the display board.
    • Remove the black tape using a precise tweezer.
    • Remove the 3.5mm Phillips #0 screw from underneath the tape.
  11. Sony XAV-AX100 Display Board Replacement: passo 11, immagine 1 di 1
    • Remove the two 2mm Phillips #0 screws from the back plate.
    • Remove the back plate.
  12. Sony XAV-AX100 Display Board Replacement: passo 12, immagine 1 di 1
    • Remove the single 2mm Phillips #0 screw from the motherboard.
  13. Sony XAV-AX100 Display Board Replacement: passo 13, immagine 1 di 1
    • Use a plastic opening tool to remove the display board from the radio.
Conclusione
USF Tampa, Team S1-G5, Cagle Spring 2018 Membro di USF Tampa, Team S1-G5, Cagle Spring 2018
USFT-CAGLE-S18S1G5
2 Membri
5 Guide realizzate
Un commento
Where can I purchase the touch panel glass screen?
Steven olivarez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,925
