Salta al contenuto principale
Sony Vaio VGN-SZ120P Keyboard Replacement
Cosa ti serve
  1. Sony Vaio VGN-SZ120P Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Keyboard Replacement: passo 2, immagine 1 di 1
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Keyboard Replacement, Keyboard: passo 3, immagine 1 di 1
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Keyboard Replacement: passo 4, immagine 1 di 2 Sony Vaio VGN-SZ120P Keyboard Replacement: passo 4, immagine 2 di 2
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Keyboard Replacement: passo 5, immagine 1 di 2 Sony Vaio VGN-SZ120P Keyboard Replacement: passo 5, immagine 2 di 2
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
Conclusione
Cal Poly, Team 25-89, Amido Spring 2010 Membro di Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Membri
63 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,539
