Salta al contenuto principale
Sony VAIO VPCEE26FX Keyboard Replacement
Cosa ti serve
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: passo 1, immagine 1 di 2 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: passo 2, immagine 1 di 2 Sony VAIO VPCEE26FX Keyboard Replacement: passo 2, immagine 2 di 2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: passo 4, immagine 1 di 1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: passo 5, immagine 1 di 2 Sony VAIO VPCEE26FX Keyboard Replacement: passo 5, immagine 2 di 2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: passo 6, immagine 1 di 2 Sony VAIO VPCEE26FX Keyboard Replacement: passo 6, immagine 2 di 2
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: passo 7, immagine 1 di 1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: passo 8, immagine 1 di 1
    • Lift the keyboard up and away from the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,163
