Salta al contenuto principale
Sony SRS-XB43 Speaker Replacement
Cosa ti serve
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: passo 1, immagine 1 di 2 Sony SRS-XB43 Speaker Replacement, Faceplate: passo 1, immagine 2 di 2
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: passo 2, immagine 1 di 1
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: passo 4, immagine 1 di 2 Sony SRS-XB43 Speaker Replacement: passo 4, immagine 2 di 2
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: passo 5, immagine 1 di 3 Sony SRS-XB43 Speaker Replacement, Speaker: passo 5, immagine 2 di 3 Sony SRS-XB43 Speaker Replacement, Speaker: passo 5, immagine 3 di 3
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: passo 7, immagine 1 di 2 Sony SRS-XB43 Speaker Replacement: passo 7, immagine 2 di 2
    • Remove the two individual speakers.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 3-5, Botvin Fall 2022 Membro di UMass Dartmouth, Team 3-5, Botvin Fall 2022
UMASSD-BOTVIN-F22S3G5
4 Membri
5 Guide realizzate
1Commento della guida
Hey I have a question how many pins on the black ribbon cable have where the cable connects to the tweeters into the main board because I accidentally broke the black ribbon cable on the right side end so I only see the two woofer with there strobe lights on and the left tweeter also the strobe works so just the right side doesn’t work so I currently have the lights off
Techspeakerpro45 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 36
Tutti i Tempi: 1,324
