Salta al contenuto principale
Sony PS1100 Needle Cartridge Replacement
  1. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: passo 1, immagine 1 di 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: passo 1, immagine 2 di 3 Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge from the player: passo 1, immagine 3 di 3
    • Place the Arm of the record player into the latch to ensure that it does not move during the needle replacement.
    • The arm must be fully locked into place
  2. Sony PS1100 Needle Cartridge Replacement, Remove the existing Cartridge: passo 2, immagine 1 di 1
    • Firmly grip both sides of the cartridge with your thumb and index fingers.
    • CAREFULLY pull the entire cartridge so that it slides out towards the front of the arm holding the needle.
  3. Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: passo 3, immagine 1 di 2 Sony PS1100 Needle Cartridge Replacement, Insert new needle cartridge: passo 3, immagine 2 di 2
    • Using the New cartridge (Sony VL-30G) gently slide into the arm of the record player. It will click into place when inserted properly.
    • Be careful not to touch the needle when inserting the cartridge or else you risk breaking the new one.
  4. Sony PS1100 Needle Cartridge Replacement, Test the new needle Cartridge: passo 4, immagine 1 di 1
    • Once the needle clicks into place, test the record player to ensure that the needle works properly.
Conclusione
L Cis
Membro da: 10/10/14
110 Reputazione
1 Guida realizzata
USF Tampa, Team 1-8, Donnelly Fall 2014 Membro di USF Tampa, Team 1-8, Donnelly Fall 2014
USFT-DONNELLY-F14S1G8
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 31
Tutti i Tempi: 4,629
