Salta al contenuto principale
Sony MDR-XB450AP Extra Bass Headphones Microphone Replacement
Cosa ti serve
  1. Sony MDR-XB450AP Extra Bass Headphones Microphone Replacement, Microphone: passo 1, immagine 1 di 1
    • Lay the headphones face up.
    • Make sure that the headphones are unplugged from any devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Microphone Replacement: passo 2, immagine 1 di 1
    • Using the metal spudger as a prying tool, gently remove the plastic casing around the microphone.
  3. Sony MDR-XB450AP Extra Bass Headphones Microphone Replacement: passo 3, immagine 1 di 1
    • Remove this piece to expose the inner workings of the microphone.
  4. Sony MDR-XB450AP Extra Bass Headphones Microphone Replacement: passo 4, immagine 1 di 1
    • With the microphone exposed you can remove the broken microphone from the wires and solder on the new piece.
    • The image shows the two points on the microphone that can be soldered.
    • Soldering can be dangerous if not performed correctly. Check out this guide for soldering tips.
Conclusione
Altre 2 persone hanno completato questa guida.
2 Commenti
Plastic casing not coming off. Any other way to take it off? My left side ain’t working and all possible wiring seems cool except the inside the microphone casing which I could not open. Please help.
Joyjeet Panday - Replica
How to close The cover of microphone
SANDIP Sen 003 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 27
Tutti i Tempi: 3,376
