Salta al contenuto principale
Sony H.ear On 2 Motherboard Replacement
Cosa ti serve
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 2 Sony H.ear On 2 Motherboard Replacement, Motherboard: passo 1, immagine 2 di 2
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: passo 2, immagine 1 di 2 Sony H.ear On 2 Motherboard Replacement: passo 2, immagine 2 di 2
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: passo 3, immagine 1 di 3 Sony H.ear On 2 Motherboard Replacement: passo 3, immagine 2 di 3 Sony H.ear On 2 Motherboard Replacement: passo 3, immagine 3 di 3
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see Come saldare e dissaldare componenti elettrici for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: passo 4, immagine 1 di 2 Sony H.ear On 2 Motherboard Replacement: passo 4, immagine 2 di 2
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: passo 5, immagine 1 di 1
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
Conclusione
Michael Long
Membro da: 04/15/19
131 Reputazione
1 Guida realizzata
Cal Poly, Team S9-G11, Maness Spring 2019 Membro di Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Membri
16 Guide realizzate
Un commento
where can i find a replacement motherboard for these headphones?
MTL - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,568
