Salta al contenuto principale
Sony H.ear On 2 Microphone Replacement
Cosa ti serve
  1. Sony H.ear On 2 Microphone Replacement, Ear Cup: passo 1, immagine 1 di 2 Sony H.ear On 2 Microphone Replacement, Ear Cup: passo 1, immagine 2 di 2
    • Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
    • This may take a considerable amount of pressure, but do not force it.
  2. Sony H.ear On 2 Microphone Replacement: passo 2, immagine 1 di 2 Sony H.ear On 2 Microphone Replacement: passo 2, immagine 2 di 2
    • Use the JIS #00 Screwdriver to remove the five 6.4 mm screws holding the back plastic cover in place.
    • Then, turn the ear cup over and carefully lift the plastic cap off to reveal the internal components of the left ear cup.
    • This same process can be repeated on the right ear cup as well. Be aware the right cup is connected to the rest of the headphones via ribbon cable.
  3. Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: passo 3, immagine 1 di 3 Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: passo 3, immagine 2 di 3 Sony H.ear On 2 Microphone Replacement, Noise Cancelling Microphone: passo 3, immagine 3 di 3
    • Use the iFixit plastic opening tool to lift the microphone out of its housing
    • Use gentle pressure to prevent damaging small wire connections
  4. Sony H.ear On 2 Microphone Replacement: passo 4, immagine 1 di 2 Sony H.ear On 2 Microphone Replacement: passo 4, immagine 2 di 2
    • Use soldering iron to desolder microphone wires from motherboard
    • Please see How to Solder and Desolder Connections before you attempt to use the soldering iron.
    • Note: Do not overheat joints while de-soldering to prevent board damage
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S9-G11, Maness Spring 2019 Membro di Cal Poly, Team S9-G11, Maness Spring 2019
CPSU-MANESS-S19S9G11
5 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,135
