Introduzione
This guide will outline how to replace the Sony FDL-220R Watchman mono-speaker. Steps include a thorough disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver, soldering station, and tweezers.
Knowledge of how to solder a basic through-hole contact is required.
Cosa ti serve
Press down on the textured area and push toward the bottom of the device.
Gently remove the battery cover.
Remove the three AA batteries.
Locate the five 5x11mm screws surrounding the battery compartment.
Remove screws with a Phillips #00 screwdriver.
Grasp the entire back half of the Watchman's casing.
Snap off the casing from the bottom of the device.
Gently pull off entire back casing.
Carefully grasp the entire circuit board.
Pull the circuit board off of the device's plastic casing.
Locate the mono-speaker on the device.
Locate the two through-hole contacts to the right of the speaker.
Touch a soldering iron to the two through-hole contacts.
While the solder is hot, pull down on the wire with tweezers.
