Introduzione
This guide will outline how to replace the Sony FDL-220R Watchman batteries and clean the battery contacts if they are corroded. Steps include basic disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver and a solution of warm water and baking soda.
Cosa ti serve
Press down on the textured area and push towards the bottom of the device.
Gently remove the battery cover.
Remove the three AA batteries.
Inspect battery contacts for any signs of damage.
Clean battery contacts with a solution of warm water and baking soda if there is corrosion.
Locate the five 5x11mm screws surrounding the battery compartment.
Remove screws with a Phillips #00 screwdriver.
Grasp the entire back half of the Watchman's casing.
Snap off casing from the bottom of the device.
Gently pull off entire back casing.
Inspect the two small springs on the back of the battery compartment.
Clean contacts with a solution of warm water and baking soda if there is corrosion.
