Salta al contenuto principale
Sony FDL-220R Watchman Antenna Replacement
Cosa ti serve
  1. Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: passo 1, immagine 1 di 2 Sony FDL-220R Watchman Antenna Replacement, Remove battery cover and batteries: passo 1, immagine 2 di 2
    • Press down on the textured area and push towards the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Antenna Replacement, Remove screws: passo 2, immagine 1 di 2 Sony FDL-220R Watchman Antenna Replacement, Remove screws: passo 2, immagine 2 di 2
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Antenna Replacement, Remove back casing: passo 3, immagine 1 di 2 Sony FDL-220R Watchman Antenna Replacement, Remove back casing: passo 3, immagine 2 di 2
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: passo 4, immagine 1 di 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: passo 4, immagine 2 di 3 Sony FDL-220R Watchman Antenna Replacement, Reattach antenna: passo 4, immagine 3 di 3
    • Locate the two metal tabs which are meant to hold the antenna in place.
    • Pry back the metal tabs with a spudger.
    • Hook the antenna into the metal tab.
    • Ensure that the antenna is fully enclosed in the metal tab.
Conclusione
Sam Putnam
Membro da: 10/22/14
484 Reputazione
4 Guide realizzate
Baylor, Team 4-5, Williams Fall 2014 Membro di Baylor, Team 4-5, Williams Fall 2014
BU-WILLIAMS-F14S4G5
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 445
