Salta al contenuto principale
Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement
Cosa ti serve
  1. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Battery: passo 1, immagine 1 di 1
    • Slide the lock at the bottom of the camera to "Open".
    • The door to the battery pack is spring loaded.
  2. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 2, immagine 1 di 1
    • Slide the blue clip up and away from the battery.
  3. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 3, immagine 1 di 1
    • Remove the battery.
  4. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: passo 4, immagine 1 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: passo 4, immagine 2 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Front and Back Panel: passo 4, immagine 3 di 3
    • Remove the six 3.5mm Phillips #000 screws.
    • Rotate the lock away from the camera.
  5. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 5, immagine 1 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 5, immagine 2 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 5, immagine 3 di 3
    • Pry the device open with the plastic opening tool.
    • There are two clips that help prevent the front panel from separating.
  6. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 6, immagine 1 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 6, immagine 2 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 6, immagine 3 di 3
    • Remove the two plastic spacers between the front and the back panels.
    • The spacers may fall out when removing the panels.
    • Carefully remove the back panel.
  7. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: passo 7, immagine 1 di 2 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Button Board: passo 7, immagine 2 di 2
    • Gently release the button board from the clips.
    • Be careful when lifting the button board; the ribbon cable will still be attached.
  8. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 8, immagine 1 di 2 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement: passo 8, immagine 2 di 2
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
  9. Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: passo 9, immagine 1 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: passo 9, immagine 2 di 3 Sony Cyber-Shot DSC-W830 Flash Capacitor Replacement, Flash Capacitor: passo 9, immagine 3 di 3
    • Caution: Be careful not to touch the capacitor wires as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Lift the capacitor from the assembly.
    • Disconnect the no-fuss ribbon cable by gently pulling it out of the flash board.
Conclusione
Tong Tang
Membro da: 09/15/16
551 Reputazione
4 Guide realizzate
USF Tampa, Team 17-1, Blackwell Fall 2016 Membro di USF Tampa, Team 17-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 780
