Salta al contenuto principale
Sony Cyber-Shot DSC-W170 LCD Replacement
Cosa ti serve
  1. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: passo 1, immagine 1 di 3 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: passo 1, immagine 2 di 3 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD Panel Assembly: passo 1, immagine 3 di 3
    • Be sure to remove the battery before performing this task.
    • Remove the five 4 mm screws with a Phillips #000 screwdriver.
  2. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 2, immagine 1 di 1
    • Use an opening pick to pry the LCD panel open.
  3. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 3, immagine 1 di 1
    • Gently remove the LCD panel from the rest of the camera.
  4. Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: passo 4, immagine 1 di 3 Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: passo 4, immagine 2 di 3 Sony Cyber-Shot DSC-W170 LCD Replacement, Front Panel: passo 4, immagine 3 di 3
    • Remove the three 4 mm screws with a Phillips #000 screwdriver.
  5. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 5, immagine 1 di 1
    • Gently open the front panel and remove it from the rest of the camera.
  6. Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: passo 6, immagine 1 di 2 Sony Cyber-Shot DSC-W170 LCD Replacement, LCD: passo 6, immagine 2 di 2
    • Remove the first side panel to the left of the LCD.
    • Remove the 4 mm screw from the other side panel to the right of the LCD with a Phillips #000 screwdriver.
  7. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 7, immagine 1 di 3 Sony Cyber-Shot DSC-W170 LCD Replacement: passo 7, immagine 2 di 3 Sony Cyber-Shot DSC-W170 LCD Replacement: passo 7, immagine 3 di 3
    • Gently, lift the LCD and carefully open the camera to disconnect the LCD ribbon cable from the motherboard.
  8. Sony Cyber-Shot DSC-W170 LCD Replacement: passo 8, immagine 1 di 2 Sony Cyber-Shot DSC-W170 LCD Replacement: passo 8, immagine 2 di 2
    • Gently push the connector through the hole to separate the LCD from the metal casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 99
