Salta al contenuto principale
Sony Cyber-Shot DSC-TX9 Flash Replacement
Cosa ti serve
  1. Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: passo 1, immagine 1 di 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: passo 1, immagine 2 di 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Prerequisites Only: passo 1, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew the six 2mm screws on the outer case of the camera.
    • If there is a battery or SD card inside remove before beginning the process.
  2. Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 2, immagine 1 di 2 Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 2, immagine 2 di 2
    • Use your hands or a Spudger to Pull off the front cover of the camera.
    • If the casing is not coming apart easily, do not force it.
  3. Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 3, immagine 1 di 1
    • Remove the protective black cover layer with your hands and set it aside.
    • The use of tweezers may be necessary if the cover is difficult to remove.
  4. Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 4, immagine 1 di 2 Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 4, immagine 2 di 2
    • The ZIF connector can be removed by flipping the small black holder into the upright position and then sliding the ribbon cable out carefully.
    • Once this has been done, use tweezers to unplug the flat topped connector for the lens’ circuit board from the motherboard.
    • DO NOT force the ribbon cables or they will rip.
    • Refer to the (Riconoscimento e scollegamento dei connettori dei cavi) page for assistance.
  5. Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: passo 5, immagine 1 di 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: passo 5, immagine 2 di 3 Sony Cyber-Shot DSC-TX9 Flash Replacement, Flash: passo 5, immagine 3 di 3
    • Remove the two screws for the metal plate on the bottom.
    • Detach the no fuse ribbon cables by sliding them out.
    • Detach the ZIF connector cables by flipping the small black holder in an upright position and then sliding the cable out carefully.
    • Remove ribbons slowly and carefully or they WILL rip.
    • Screws are of Phillips type, head size Y0 and 0.3 mm in length.
  6. Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 6, immagine 1 di 3 Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 6, immagine 2 di 3 Sony Cyber-Shot DSC-TX9 Flash Replacement: passo 6, immagine 3 di 3
    • Carefully remove the Memory card circuit board. You will then be able to see the flash with the capacitors connected.
    • Using tweezers, carefully remove the components. They are all connected together.
    • The circuit board should come out with little force. If it does not, make sure all connections are disconnected.
Conclusione
Yegor Shea
Membro da: 03/26/17
301 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 297
