Salta al contenuto principale
Sony BDP-s7200 Power Supply Board Replacement
Cosa ti serve
  1. Sony BDP-s7200  Power Supply Board Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove the disk tray cover from the device.
  2. Sony BDP-s7200  Power Supply Board Replacement: passo 2, immagine 1 di 2 Sony BDP-s7200  Power Supply Board Replacement: passo 2, immagine 2 di 2
    • Using the Phillips #2 Screwdriver, remove the five 9mm from the bottom of the device.
    • Remove the metal cover.
  3. Sony BDP-s7200  Power Supply Board Replacement: passo 3, immagine 1 di 2 Sony BDP-s7200  Power Supply Board Replacement: passo 3, immagine 2 di 2
    • Using the Phillips #2 Screwdriver, remove the six 9mm screws from the back of the device.
  4. Sony BDP-s7200  Power Supply Board Replacement: passo 4, immagine 1 di 1
    • Pull off the back panel and remove it from the device.
  5. Sony BDP-s7200  Power Supply Board Replacement, Front Panel Cover: passo 5, immagine 1 di 3 Sony BDP-s7200  Power Supply Board Replacement, Front Panel Cover: passo 5, immagine 2 di 3 Sony BDP-s7200  Power Supply Board Replacement, Front Panel Cover: passo 5, immagine 3 di 3
    • Using the plastic opening tool, open one of the tabs on the bottom of the device.
    • While keeping the tab open, insert a opening pick in between the opening tool and tab.
    • Repeat this for the 3 other tabs.
  6. Sony BDP-s7200  Power Supply Board Replacement: passo 6, immagine 1 di 2 Sony BDP-s7200  Power Supply Board Replacement: passo 6, immagine 2 di 2
    • Place your hands on the two black circles on the bottom of the device.
    • Pull on the black circles to remove the device from its front panel cover.
  7. Sony BDP-s7200  Power Supply Board Replacement: passo 7, immagine 1 di 3 Sony BDP-s7200  Power Supply Board Replacement: passo 7, immagine 2 di 3 Sony BDP-s7200  Power Supply Board Replacement: passo 7, immagine 3 di 3
    • Using the Phillips #2 Screwdriver, remove the seven 9mm screws from the top of the device.
    • Using the same screwdriver, remove the three 9mm screws from the back of the device.
    • Using the same screwdriver, remove the one 9mm screw still connecting the small metal clip to the front of the device.
  8. Sony BDP-s7200  Power Supply Board Replacement: passo 8, immagine 1 di 2 Sony BDP-s7200  Power Supply Board Replacement: passo 8, immagine 2 di 2
    • Remove the small metal clip on the front of the device.
    • Remove the metal cover on the top of the device.
  9. Sony BDP-s7200  Power Supply Board Replacement, Power Supply Board: passo 9, immagine 1 di 1
    • Remove the ribbon cables that connect to the front panel board.
    • Pull firmly, but not too hard as to not damage the ribbon cable.
  10. Sony BDP-s7200  Power Supply Board Replacement: passo 10, immagine 1 di 1
    • Remove the power supply board cable connected to the motherboard.
  11. Sony BDP-s7200  Power Supply Board Replacement: passo 11, immagine 1 di 1
    • Remove the 2 screws using the Phillips #2 screwdriver
    • Slide the power cord out of it's slot in the frame.
  12. Sony BDP-s7200  Power Supply Board Replacement: passo 12, immagine 1 di 2 Sony BDP-s7200  Power Supply Board Replacement: passo 12, immagine 2 di 2
    • Remove the Power Supply Board.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 14
Tutti i Tempi: 845
