Salta al contenuto principale
Sony BDP-S3500 Motherboard Replacement
Cosa ti serve
  1. Sony BDP-S3500 Motherboard Replacement, Front Panel: passo 1, immagine 1 di 2 Sony BDP-S3500 Motherboard Replacement, Front Panel: passo 1, immagine 2 di 2
    • Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
  2. Sony BDP-S3500 Motherboard Replacement: passo 2, immagine 1 di 1
    • Slide the top panel off towards the back of the device.
    • Remove the top panel.
  3. Sony BDP-S3500 Motherboard Replacement: passo 3, immagine 1 di 2 Sony BDP-S3500 Motherboard Replacement: passo 3, immagine 2 di 2
    • Unclip the plastic tags from the bottom of the device.
    • Unclip the plastic tags from the sides of the device.
    • Slide the front panel off.
  4. Sony BDP-S3500 Motherboard Replacement, Disk Drive: passo 4, immagine 1 di 2 Sony BDP-S3500 Motherboard Replacement, Disk Drive: passo 4, immagine 2 di 2
    • Remove the three ribbon cables by gently pulling the cables out of each connector.
    • Be sure to only handle the circuit board from the edges so that the PCB is not damaged.
  5. Sony BDP-S3500 Motherboard Replacement: passo 5, immagine 1 di 2 Sony BDP-S3500 Motherboard Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the two 9mm screws that are holding the disk drive in place.
  6. Sony BDP-S3500 Motherboard Replacement: passo 6, immagine 1 di 2 Sony BDP-S3500 Motherboard Replacement: passo 6, immagine 2 di 2
    • Carefully lift and slide the disk drive out of the casing.
  7. Sony BDP-S3500 Motherboard Replacement, Motherboard: passo 7, immagine 1 di 2 Sony BDP-S3500 Motherboard Replacement, Motherboard: passo 7, immagine 2 di 2
    • Remove the ribbon cables by holding onto the cable and gently pulling straight up.
  8. Sony BDP-S3500 Motherboard Replacement: passo 8, immagine 1 di 3 Sony BDP-S3500 Motherboard Replacement: passo 8, immagine 2 di 3 Sony BDP-S3500 Motherboard Replacement: passo 8, immagine 3 di 3
    • Use the Phillips #2 screwdriver to remove three 9mm screws securing the motherboard to the case.
    • Remove one 5.5mm Phillips #2 from the back of the case near the ports.
  9. Sony BDP-S3500 Motherboard Replacement: passo 9, immagine 1 di 1
    • Slide the motherboard away from the back of the case and then lift up to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 16
Tutti i Tempi: 483
