Introduzione
This is a guide to remove the front panel assembly of the Sony BDP S3500.
Be sure to review the troubleshooting guide, as most of the time the problems are due malfunctioning software rather than it being a hardware issue.
This guide will show you how to safely remove the front panel assembly without damaging the other components.
Cosa ti serve
Use the Phillips #2 screwdriver to remove the two 9mm screws located on the back of the device.
Altre 2 persone hanno completato questa guida.
