Introduzione
This guide will begin by taking off back cover of screen assembly. The guide will then explain how to uncover and disconnect the LCD Ribbon cable. The screen will then be removed from the screen mount assembly.
Cosa ti serve
Turn the camera off by switching the power knob "OFF" text to the white selector dot.
Remove the two 1.0 mm Phillips #00 screws from back of the LCD screen.
Remove the two 1.5 mm Phillips #00 screws from the bottom of the screen mount assembly.
Strumento utilizzato in questo passaggio:Tweezers$4.99
Using a plastic opening tool pry off the back cover from the screen assembly.
Remove back cover by lifting it away from the screen using tweezers.
Release the ribbon cable by lifting the black locking latch with the plastic opening tool.
Pry out the ribbon cable by carefully sliding it out of the connection slot using a spudger.
Lift and slide out the upper black plastic separator using tweezers.
Lift and remove the lower black plastic separator using tweezers.
Using the pointy side of a spudger push in the screen lock button release it.
The screen lock button can now be removed.
Using the flat end of the spudger, push on the black nylon sheet glued to the metallic frame to peel it of.
Remove the black nylon sheet using tweezers.
Altre 6 persone hanno completato questa guida.
2Commenti sulla guida
Hi - I am trying to fix one of these -- and the guy I bought it from pulled off and lost the black locking latch from the ribbon cable rather than just lifting it -- I can get the LCD screen to light but can't keep it on very long -- I bought another one of these internal cables with the black locking latch. Do you think I can pop that one off and move it to this one? Or do you have any source of instructions how to replace that cable?
Cheers and thanks for this!
PS -- If anyone is just trying to get rid of the dreaded bubbles in the screen saver that plagues these NEX cameras -- it does just peal off -- see youtubes,,,
