Salta al contenuto principale
Sony Alpha NEX-3N Sensor Replacement
  1. Sony Alpha NEX-3N Sensor Replacement, Getting Started: passo 1, immagine 1 di 2 Sony Alpha NEX-3N Sensor Replacement, Getting Started: passo 1, immagine 2 di 2
    • Remove battery and card
  2. Sony Alpha NEX-3N Sensor Replacement, Back Case 1: passo 2, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 1: passo 2, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 1: passo 2, immagine 3 di 3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N Sensor Replacement, Back Case 2: passo 3, immagine 1 di 1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N Sensor Replacement, Back Case 3: passo 4, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 3: passo 4, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, Back Case 3: passo 4, immagine 3 di 3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N Sensor Replacement, LCD assembly: passo 5, immagine 1 di 2 Sony Alpha NEX-3N Sensor Replacement, LCD assembly: passo 5, immagine 2 di 2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: passo 6, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: passo 6, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, LCD Assembly: passo 6, immagine 3 di 3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N Sensor Replacement, The LCD assembly: passo 7, immagine 1 di 1
    • The LCD assembly
  8. Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: passo 8, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: passo 8, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: passo 8, immagine 3 di 3
    • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
    • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
  9. Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: passo 9, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: passo 9, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, Dismantle the LCD Part: passo 9, immagine 3 di 3
    • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
    • the the circle marker that show others ribbon you need to be carefull. goodluck!
  10. Sony Alpha NEX-3N Sensor Replacement, Keypad: passo 10, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, Keypad: passo 10, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, Keypad: passo 10, immagine 3 di 3
    • Lift the keypad.
    • Detach FPC
  11. Sony Alpha NEX-3N Sensor Replacement, Screws: passo 11, immagine 1 di 1
    • Remove 3 M1.4x3.6 black screws, 2 of them out of focus
  12. Sony Alpha NEX-3N Sensor Replacement: passo 12, immagine 1 di 2 Sony Alpha NEX-3N Sensor Replacement: passo 12, immagine 2 di 2
    • Slide the flash assembly backwards with caution.
    • Detach flash FPC by pulling it out of the socket.
    • High Voltage! Do NOT touch metal on FPC.
    • Then remove the flash assembly.
  13. Sony Alpha NEX-3N Sensor Replacement: passo 13, immagine 1 di 1
    • Remove that part whatever called, by sliding it backwards.
  14. Sony Alpha NEX-3N Sensor Replacement, Screws: passo 14, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, Screws: passo 14, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, Screws: passo 14, immagine 3 di 3
    • 1 ST1.7x5
    • 2 ST1.7x5
    • 1 M1.4x3.6 black
  15. Sony Alpha NEX-3N Sensor Replacement, The Grip: passo 15, immagine 1 di 2 Sony Alpha NEX-3N Sensor Replacement, The Grip: passo 15, immagine 2 di 2
    • Remove 2 ST1.7x5 screws from inside the battery bay. (one of them not shown, deeper inside) insert screw driver through a hole in the shielding cover.
    • Pop the grip off. From back, push to the right, then it flies forward.
  16. Sony Alpha NEX-3N Sensor Replacement, More Screws: passo 16, immagine 1 di 1
    • Remove 2 M1.4x2 black screws
  17. Sony Alpha NEX-3N Sensor Replacement, Pop the Shielding Cover: passo 17, immagine 1 di 2 Sony Alpha NEX-3N Sensor Replacement, Pop the Shielding Cover: passo 17, immagine 2 di 2
    • with caution and patient.
  18. Sony Alpha NEX-3N Sensor Replacement, One More Shield: passo 18, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, One More Shield: passo 18, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, One More Shield: passo 18, immagine 3 di 3
    • 1 M1.4x3.6
  19. Sony Alpha NEX-3N Sensor Replacement, Detach 7000 FPCs: passo 19, immagine 1 di 1
    • Sensor power, flip
    • Sensor signal, flip
    • Shutter, pull
    • Lens contacts, pull. Did I mention that Sony makes world's most brittle FPC?
    • Whatever, pull
    • Whatever, pull
    • Shutter charger motor FPC, (backside, pull out)
  20. Sony Alpha NEX-3N Sensor Replacement: passo 20, immagine 1 di 1
    • Flip the Mainboard up
    • Pull out one more FPC
    • Discharge then desolder 4 wires.
    • CAUTION! Possible high DC voltage >300V
  21. Sony Alpha NEX-3N Sensor Replacement: passo 21, immagine 1 di 1
    • Lift main board and plastic frame with flash capacitor.
  22. Sony Alpha NEX-3N Sensor Replacement, FPC cables: passo 22, immagine 1 di 1
    • Detach sensor Power (L)and Signal(R) FPC
  23. Sony Alpha NEX-3N Sensor Replacement, Screws: passo 23, immagine 1 di 1
    • Remove 3-4 ST1.7x5 screws
    • Remove 1 M1.4x5 screw
  24. Sony Alpha NEX-3N Sensor Replacement: passo 24, immagine 1 di 2 Sony Alpha NEX-3N Sensor Replacement: passo 24, immagine 2 di 2
    • Remove 4 ST1.7x5 screws for the E-Mount
    • Remove mount metal ring
  25. Sony Alpha NEX-3N Sensor Replacement, E-Mount: passo 25, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, E-Mount: passo 25, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, E-Mount: passo 25, immagine 3 di 3
    • Remove mount plastic ring
    • remove mount spring ring
  26. Sony Alpha NEX-3N Sensor Replacement, Sensor + Shutter: passo 26, immagine 1 di 1
    • Sensor + Shutter assembly comes off
  27. Sony Alpha NEX-3N Sensor Replacement, Sensor Frame: passo 27, immagine 1 di 1
    • Separate sensor + shutter from another frame
  28. Sony Alpha NEX-3N Sensor Replacement, The Sensor: passo 28, immagine 1 di 3 Sony Alpha NEX-3N Sensor Replacement, The Sensor: passo 28, immagine 2 di 3 Sony Alpha NEX-3N Sensor Replacement, The Sensor: passo 28, immagine 3 di 3
    • Remove 3 ST1.7x5 screws
    • Remove sensor shield / heat sink. Sensor PCBA might sticks to the shield, just separate them.
Conclusione
Terrance
Membro da: 11/17/09
6.765 Reputazione
18 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 411
