Salta al contenuto principale
Sony Alpha NEX-3N LCD assembly Replacement
Cosa ti serve
  1. Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: passo 1, immagine 1 di 2 Sony Alpha NEX-3N LCD assembly Replacement, Getting Started: passo 1, immagine 2 di 2
    • Remove battery and card
  2. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: passo 2, immagine 1 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: passo 2, immagine 2 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 1: passo 2, immagine 3 di 3
    • Right side, remove 1 M1.4x3.7 screw
    • Left side, remove 3 M1.4x3.7 screws
    • Bottom side, remove 5 M1.4x3.7 screws, including 2 in battery bay. 2 of them out of this photo, you can find them.
    • Do NOT touch screws on the bottom of LCD assembly.
  3. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 2: passo 3, immagine 1 di 1
    • Pop the flash.
    • In flash room, remove 1 (one) M1.4x3.8 black screw.
  4. Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: passo 4, immagine 1 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: passo 4, immagine 2 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Back Case 3: passo 4, immagine 3 di 3
    • Remove LCD hinge cover, by sliding to the left.
    • Remove back cover, actually just a plastic frame.
  5. Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: passo 5, immagine 1 di 2 Sony Alpha NEX-3N LCD assembly Replacement, LCD assembly: passo 5, immagine 2 di 2
    • Remove 1 M1.4x2 screw
    • Remove another M1.4x2 screw, sorry for the angle.
  6. Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: passo 6, immagine 1 di 3 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: passo 6, immagine 2 di 3 Sony Alpha NEX-3N LCD assembly Replacement, LCD Assembly: passo 6, immagine 3 di 3
    • CAUTION. Sony makes world's MOST BRITTLE FPC!
    • Loosen LCD assemble with caution!
    • Release FPC cable, the connector is flip type.
  7. Sony Alpha NEX-3N LCD assembly Replacement, The LCD assembly: passo 7, immagine 1 di 1
    • The LCD assembly
  8. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: passo 8, immagine 1 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: passo 8, immagine 2 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: passo 8, immagine 3 di 3
    • After unscrew 4pcs screw you will remove the steel black plate, then slowly pull the black frame there to see the ribbon stripe.
    • Slowly pull the very fragile ribbon lock which i marking with the blue boxes. around just 1mm to unlock the ribbon.. unlucky i broke mine..
  9. Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: passo 9, immagine 1 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: passo 9, immagine 2 di 3 Sony Alpha NEX-3N LCD assembly Replacement, Dismantle the LCD Part: passo 9, immagine 3 di 3
    • you can see the ribbon already pull out but be carefull with the others 2 ribbon when your try to pull out this ribbon.
    • the the circle marker that show others ribbon you need to be carefull. goodluck!
Conclusione
Terrance
Membro da: 11/17/09
6.765 Reputazione
18 Guide realizzate
2Commenti sulla guida
Where can i get a lcd screen replacement?
Searched everywhere even AliExpress they do not sell the replacement lcd for this model
adfa dad - Replica
No idea. I broke 2 FPC and lost some lens contact springs, got no where to buy, planning to replace the FPCs, but too busy these days .........
Terrance -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 63
Tutti i Tempi: 2,441
