Salta al contenuto principale
Solio Rocsta Charging Cable Replacement
Cosa ti serve
  1. Solio Rocsta Charging Cable Replacement, Charging Cable: passo 1, immagine 1 di 2 Solio Rocsta Charging Cable Replacement, Charging Cable: passo 1, immagine 2 di 2
    • Locate, and unscrew, the three 5.72 mm screws that hold down the top cover using the T6 Torx screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Solio Rocsta Charging Cable Replacement: passo 2, immagine 1 di 2 Solio Rocsta Charging Cable Replacement: passo 2, immagine 2 di 2
    • Remove top cover.
    • Caution: the solar cell is attached to the top cover and connected to the circuit board by a short wire.
    Chiedi a FixBot
    Aggiungi Commento
  3. Solio Rocsta Charging Cable Replacement: passo 3, immagine 1 di 1
    • Using the spudger, pry the battery off the back cover.
    Chiedi a FixBot
    Aggiungi Commento
  4. Solio Rocsta Charging Cable Replacement: passo 4, immagine 1 di 1
    • Unscrew the 5.66 mm screws attaching the circuit board to the case.
    Chiedi a FixBot
    Aggiungi Commento
  5. Solio Rocsta Charging Cable Replacement: passo 5, immagine 1 di 1
    • With the circuit board flipped, locate the battery connector.
    • Hold the component attached to the circuit board the battery is connected to and wiggle the cable out.
    Chiedi a FixBot
    Aggiungi Commento
  6. Solio Rocsta Charging Cable Replacement: passo 6, immagine 1 di 1
    • With a Soldering Iron, desolder the four cables that connect the charging cable to the circuit board.
    • The power cable is a series of four cables. Make note of each cable placement for easy resoldering.
    • For more information on how to solder and desolder connections, please visit this guide.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
USF Tampa, Team S13-G13, Cagle Fall 2017 Membro di USF Tampa, Team S13-G13, Cagle Fall 2017
USFT-CAGLE-F17S13G13
4 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 26
Tutti i Tempi: 427
