Salta al contenuto principale
Slingbox SOLO DC Power Connector Replacement
Cosa ti serve
  1. Slingbox SOLO DC Power Connector Replacement, Motherboard: passo 1, immagine 1 di 1
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO DC Power Connector Replacement: passo 2, immagine 1 di 3 Slingbox SOLO DC Power Connector Replacement: passo 2, immagine 2 di 3 Slingbox SOLO DC Power Connector Replacement: passo 2, immagine 3 di 3
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO DC Power Connector Replacement: passo 3, immagine 1 di 3 Slingbox SOLO DC Power Connector Replacement: passo 3, immagine 2 di 3 Slingbox SOLO DC Power Connector Replacement: passo 3, immagine 3 di 3
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
  4. Slingbox SOLO DC Power Connector Replacement, DC Power Connector: passo 4, immagine 1 di 1
    • Do not touch the heated tip of the soldering iron.
    • Check this guide out to learn how to use a soldering iron.
    • Desolder all three lead prongs.
    • Gently pull the DC power connector from the motherboard.
Conclusione
To reassemble your device, follow the instructions in reverse order.
IUPUI, Team 2-2, Harley SU 2016 Membro di IUPUI, Team 2-2, Harley SU 2016
IUPUI-HARLEY-SU16S2G2
5 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 300
