Salta al contenuto principale
Skytex Skypad Alpha 2 Speaker Replacement
Cosa ti serve
  1. Skytex Skypad Alpha 2 Speaker Replacement, Back Cover: passo 1, immagine 1 di 1
    • Power off the tablet.
    • Unplug the tablet from the power source if it is connected.
  2. Skytex Skypad Alpha 2 Speaker Replacement: passo 2, immagine 1 di 2 Skytex Skypad Alpha 2 Speaker Replacement: passo 2, immagine 2 di 2
    • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
  3. Skytex Skypad Alpha 2 Speaker Replacement: passo 3, immagine 1 di 1
    • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
  4. Skytex Skypad Alpha 2 Speaker Replacement: passo 4, immagine 1 di 1
    • Release the back case from the rest of the tablet with your hand.
    • Do not pry the case too hard; doing so can damage the tablet.
  5. Skytex Skypad Alpha 2 Speaker Replacement, Speaker: passo 5, immagine 1 di 1
    • Remove the soldered connections to separate the speaker wires from the motherboard.
    • Remove all black and yellow tape, if necessary, on the motherboard.
    • Following the red and black wires, coming out of the speaker, to their respective connections on the motherboard will indicate where to solder.
    • Follow the link below for further soldering information: How To Solder and Desolder Connections.
    • Soldering irons require a larger amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
  6. Skytex Skypad Alpha 2 Speaker Replacement: passo 6, immagine 1 di 1
    • Remove the speaker from the tablet using the plastic opening tool.
    • This will not require much force, prying from the flat side of the speaker will do the job.
Conclusione
Baylor, Team 6-5, Williams Fall 2015 Membro di Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 135
