Salta al contenuto principale
Skytex Skypad Alpha 2 Antenna Replacement
Cosa ti serve
    1. Skytex Skypad Alpha 2 Antenna Replacement, Back Cover: passo 1, immagine 1 di 1
      • Power off the tablet.
      • Unplug the tablet from the power source if it is connected.
      Chiedi a FixBot
      Aggiungi Commento
    2. Skytex Skypad Alpha 2 Antenna Replacement: passo 2, immagine 1 di 2 Skytex Skypad Alpha 2 Antenna Replacement: passo 2, immagine 2 di 2
      • Remove the (4) 3.5mm screws using a phillips #000 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    3. Skytex Skypad Alpha 2 Antenna Replacement: passo 3, immagine 1 di 1
      • Use the plastic opening tool to work your way around the tablet, releasing the back case from the tabs.
      Chiedi a FixBot
      Aggiungi Commento
    4. Skytex Skypad Alpha 2 Antenna Replacement: passo 4, immagine 1 di 1
      • Release the back case from the rest of the tablet with your hand.
      • Do not pry the case too hard; doing so can damage the tablet.
      Chiedi a FixBot
      Aggiungi Commento
    1. Skytex Skypad Alpha 2 Antenna Replacement, Antenna: passo 5, immagine 1 di 1
      • Remove the metallic electrical tape, just enough, to allow the antenna to hang freely.
      • Remove all black and yellow tape, if necessary, on the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    2. Skytex Skypad Alpha 2 Antenna Replacement: passo 6, immagine 1 di 1
      • Remove the soldered connections to separate the antenna wire from the motherboard.
      • The antenna wire will be connected to the motherboard with 2 connections, so be sure to remove both with the soldering iron.
      • Follow the link below for further soldering information: How To Solder and Desolder Connections.
      • Soldering irons require a large amount of heat; use caution when performing this step. Excessive heat can damage parts of your device; do not leave the soldering iron on connections for extended periods of time.
      Chiedi a FixBot
      Aggiungi Commento
    3. Skytex Skypad Alpha 2 Antenna Replacement: passo 7, immagine 1 di 1
      Strumento utilizzato in questo passaggio:
      • Remove the antenna from the tablet using a pair of tweezers.
      • The antenna is actually fastened inside the back case of the tablet, pull gently to free it from the adhesive.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Baylor, Team 6-5, Williams Fall 2015 Membro di Baylor, Team 6-5, Williams Fall 2015
BU-WILLIAMS-F15S6G5
3 Membri
48 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 27
Ultimi 30 giorni: 43
Tutti i Tempi: 389
