Introduzione
This repair guide will walk you through the primary steps of replacing the battery in the Skytex Skypad SP728.
Cosa ti serve
Make sure the device is powered off
Rotate the device so the ports and screws face you
Use the soldering iron and remove soldered connections to separate the wires connected to the battery from the circuit board.
Follow the link below for additional soldering information Come saldare e dissaldare componenti elettrici
To reassemble your device with a new battery, follow these instructions in reverse order.
