Salta al contenuto principale
Skullcandy UPROCK Earpiece Wiring Replacement
Cosa ti serve
  1. Skullcandy UPROCK Earpiece Wiring Replacement, Earpiece Wiring: passo 1, immagine 1 di 1
    • Remove the cushion from the ear piece.
  2. Skullcandy UPROCK Earpiece Wiring Replacement: passo 2, immagine 1 di 2 Skullcandy UPROCK Earpiece Wiring Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #0 to unscrew three 3.4MM screws from the earpiece.
  3. Skullcandy UPROCK Earpiece Wiring Replacement: passo 3, immagine 1 di 2 Skullcandy UPROCK Earpiece Wiring Replacement: passo 3, immagine 2 di 2
    • Find the wires connected to the speaker and check if they are intact.
  4. Skullcandy UPROCK Earpiece Wiring Replacement: passo 4, immagine 1 di 1
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Un commento
my jack is broken can i get a whole new wire so i could do soldering or can i use any other wire. if i use any other wire can i connect in btw of old wire coz i removed the jack by cutting the wire from jack or do i have to do soldering from beginning form inside.
Anuj Verma - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 6,213
