Introduzione
Click here for the updated version of this guide. This version is archived for historical purposes and should not be used.
Cosa ti serve
First step: get screen.
I found mine here: https://www.ebay.de/itm/6-ED060SCE-E-ink...
You might want to recharge it. Turning it completely off might be a good idea.
Open the casings by unclicking the plastic hooks on the back. I found it easiest to start at the upper corners and the bottom middle and leave the places with the buttons for last. In the center of the casing are two additional plastic hooks pointing downwards - when you think you should be done try sliding the back a bit down.
Remove Screen cable to the left.
Remove board, slightly pushing up and left.
Push broken screen out of the frame - gently pressing from the outside to the inside. I did not need tools for this, but be careful not to break the frame. Unpack replacement screen, remove protection foil and carefully place it. The glue should still be sufficient.
Rearrange keyboard top which has probably fallen off, insert board, some screws and screen cable. Test before closing the case. If not charged beforehand, remember it still might be charging for some time before anything will happen on the screen.
2 Commenti
how much do the tools cost for removing the stuff
Hi, I just wanted to know how your screen got broken. My kid was playing with my Kindle and left it lying on the floor and I stepped on it. I was therefore wondering if only the screen is damaged (it looks the same as the one in your picture, but I can't seem to turn it off at all). Thanks, Monika
Monika - Replica
At least one of my screens broke when I stepped on it myself. In all probability this is everything that’s wrong with yours, too. You say you cannot turn it off: do you say that because the screen contents do not change? Since it’s e-ink it won’t change anymore if the screen does not work. However, if you say that the behavior of the the on/off LED has changed, that would be different.
axm - Replica
