Salta al contenuto principale
Sharper Image iPulse SI325 Motherboard Replacement
Cosa ti serve
  1. Sharper Image iPulse SI325 Motherboard Replacement, Outer Case: passo 1, immagine 1 di 2 Sharper Image iPulse SI325 Motherboard Replacement, Outer Case: passo 1, immagine 2 di 2
    • Gently position the device so that the buttons and speakers lie face down.
    • Unplug the power cord from the "DC Input."
  2. Sharper Image iPulse SI325 Motherboard Replacement: passo 2, immagine 1 di 3 Sharper Image iPulse SI325 Motherboard Replacement: passo 2, immagine 2 di 3 Sharper Image iPulse SI325 Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
    • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
    • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
    • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
    • A small gap will open as the two tabs are released.
    • Do not pull the two halves apart yet. They are held together by the speaker wire.
  3. Sharper Image iPulse SI325 Motherboard Replacement: passo 3, immagine 1 di 2 Sharper Image iPulse SI325 Motherboard Replacement: passo 3, immagine 2 di 2
    • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
    • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
    • Lay the device down, so that all the internal components are facing upwards.
  4. Sharper Image iPulse SI325 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Turn the device over so that the internals are facing down.
    • Remove the three 7mm Phillips #1 screws connecting the Zipconnect unit.
  5. Sharper Image iPulse SI325 Motherboard Replacement: passo 5, immagine 1 di 2 Sharper Image iPulse SI325 Motherboard Replacement: passo 5, immagine 2 di 2
    • Turn the device over again so you are looking at the internals.
    • The Zipconnect unit will lift out but will still be attached by a wire connected to the motherboard.
    • Remove the six 7mm Phillips #1 phillips screws attatching the Zipconnect unit to the motherboard wire and set the unit out of the way.
  6. Sharper Image iPulse SI325 Motherboard Replacement: passo 6, immagine 1 di 2 Sharper Image iPulse SI325 Motherboard Replacement: passo 6, immagine 2 di 2
    • Disconnect the speaker wire from the motherboard by firmly griping the wires close to the connection with two fingers and pull the connector out.
    • Wiggling the connector back and forth as you pull will make removal easier.
  7. Sharper Image iPulse SI325 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the two 11mm Phillips #1 screws attaching the small brown circuit board to the plastic outer case.
    • Also remove the four 11mm Phillips #1 screws attaching the motherboard to the plastic case.
  8. Sharper Image iPulse SI325 Motherboard Replacement: passo 8, immagine 1 di 3 Sharper Image iPulse SI325 Motherboard Replacement: passo 8, immagine 2 di 3 Sharper Image iPulse SI325 Motherboard Replacement: passo 8, immagine 3 di 3
    • Lift up on both the motherboard and brown circuit board which contains the light intensity dial.
    • Turn over the motherboard and remove the solder connecting the wide, flat, grey wire.
Conclusione
Vi Le
Membro da: 10/14/13
101 Reputazione
1 Guida realizzata
Cal Poly, Team 11-33, Amido Fall 2013 Membro di Cal Poly, Team 11-33, Amido Fall 2013
CPSU-AMIDO-F13S11G33
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 538
