Salta al contenuto principale
Shark Rocket Powerhead AH401 Belt Replacement
Cosa ti serve
  1. Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: passo 1, immagine 1 di 3 Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: passo 1, immagine 2 di 3 Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: passo 1, immagine 3 di 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Belt Replacement: passo 2, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 2, immagine 2 di 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Belt Replacement, Back Panel Screws: passo 3, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement, Back Panel Screws: passo 3, immagine 2 di 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
    How do you take the handle off so I can ship it back
    Robert Pearsall - Replica
  4. Shark Rocket Powerhead AH401 Belt Replacement, Filter Grille: passo 4, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement, Filter Grille: passo 4, immagine 2 di 2
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  5. Shark Rocket Powerhead AH401 Belt Replacement: passo 5, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 5, immagine 2 di 2
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  6. Shark Rocket Powerhead AH401 Belt Replacement, Belt: passo 6, immagine 1 di 1
    • Remove the four screws by rotating counter-clockwise:
    • One 12 mm screw with a T10 Torx screwdriver
    • Three 14 mm screw with a T15 Torx screwdriver
  7. Shark Rocket Powerhead AH401 Belt Replacement: passo 7, immagine 1 di 3 Shark Rocket Powerhead AH401 Belt Replacement: passo 7, immagine 2 di 3 Shark Rocket Powerhead AH401 Belt Replacement: passo 7, immagine 3 di 3
    • Remove the grey filter plate by simply lifting upward.
    • Remove the 14mm screw by rotating counter clockwise with a T10 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Belt Replacement: passo 8, immagine 1 di 1
    • Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
    YOU LEFT OUT THE HARDEST PART. I HAVE SPENT 1HR TRYING TO REMOVE THE MOTOR COMPARTMENT PANEL. THERE HAS TO BE A TRICK TO IT! BUT WHY ? WHY ? NOT PUT IT IN!!!! arggggg!!!
    nm1hart - Replica
    STEP 9-YOU LEFT OUT THE HARDEST PART. I HAVE SPENT 1HR TRYING TO REMOVE THE MOTOR COMPARTMENT PANEL. THERE HAS TO BE A TRICK TO IT! BUT WHY ? WHY ? NOT PUT IT IN!!!! arggggg!!!
    nm1hart - Replica
  9. Shark Rocket Powerhead AH401 Belt Replacement: passo 9, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 9, immagine 2 di 2
    • Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
    I can't complete this step; the airpath grille is under a panel. I'm not able to remove this panel, maybe I'm missing something?
    Michelle Garcia - Replica
    same here did you miss a step in removing the airpath grill cover
    m_sabr - Replica
    The same here! I cannot remove the air path grille because of covering. How do I, (we) remove covering. It doesn't just come off.
    Susang - Replica
  10. Shark Rocket Powerhead AH401 Belt Replacement: passo 10, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 10, immagine 2 di 2
    • Remove the motor compartment panel by lifting up and away from the device.
    The trick to removing this motor compartment panel: Wiggle it loose first. Then get an index and middle finger under the FRONT-LEFT L-shaped section of the panel (to the left of the screw hole, behind the spring mechanism). PULL STRAIGHT UP. You are going to likely get uncomfortable with the amount of pressure this requires and you might think you will break it. Keep working at it. Index and middle finger lifting it straight up. When it comes up, the spring mechanism might fall off. It's okay. You didn't break it. The motor compartment panel will pop off (up) eventually.
    zhicor - Replica
    Thank you for responding! Is this what you mean? I can lift the left side a bit, but the right side near the black motor vent is not budging.
    I took a photo but I can't figure out how to insert it in replies.
    Susang -
  11. Shark Rocket Powerhead AH401 Belt Replacement: passo 11, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 11, immagine 2 di 2
    • Remove one 14mm screw by rotating counter-clockwise with a T15 Torx screwdriver.
  12. Shark Rocket Powerhead AH401 Belt Replacement: passo 12, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 12, immagine 2 di 2
    • Disconnect the motor side panel by lifting the motor and panel up and out.
    • This step may require some wiggling to loosen the panel before it becomes free.
  13. Shark Rocket Powerhead AH401 Belt Replacement: passo 13, immagine 1 di 1
    • Remove one 9mm screw by rotating counter-clockwise with a Phillips #2 screwdriver.
    • This screw allows the side panel to be removed.
  14. Shark Rocket Powerhead AH401 Belt Replacement: passo 14, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 14, immagine 2 di 2
    • Remove the side panel by pulling the panel out and away from the motor.
    • The side panel is connected with clips which connect near the brushroll axle.
  15. Shark Rocket Powerhead AH401 Belt Replacement: passo 15, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 15, immagine 2 di 2
    • Loosen the two screws by rotating counter clockwise with a T15 Torx screwdriver.
    • The screws only need to be loosened in order to free the belt.
  16. Shark Rocket Powerhead AH401 Belt Replacement: passo 16, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 16, immagine 2 di 2
    • Remove the belt by pulling the belt away from the axle.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro di Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membri
18 Guide realizzate
15 Commenti
These instructions were fantastic accept for one section. On Step 9 you never mention to first remove the Motor Compartment Panel before removing the airpath grille. The picture just shows the panel already removed. Otherwise, I followed the directions forwards and backwards and I was successful!! I went to the local vacuum repair store to purchase a new belt. They did not have the Shark belt so I purchased the Bissell BIBL, BELT geared 80R4, 47A2 for $3.50 and it worked perfectly!!
Liz Needham - Replica
there is a hidden screw on the outside of the compartment/ motor side where the handle mets the motor compartment panel / in the corner iif i could leave a pic i would.
nm1hart -
is the Shark 400 and 401 the same in changing the dive belt?
Alfonso Luna - Replica
What is the replacement belt part#? Did I miss that somewhere here? I can’t find it on their web site or anywhere else on line using the AH401 model #, thanks
Mark Pugliese - Replica
I have an AH452 and the belt number is 4315 SC or Gates # 192-3GT6-SAR
Walt Shuler -
Also, my model requires the TR drivers (security torx drivers with hole in the middle) which isn’t clear in this instruction
nm1hart - Replica
Great step-by-step instructions. I thought the belt was broken on my Model AH401 but when I finally got to to the drive mechanism, I discovered that the metal brush roller axel had broken away from the white plastic gear (shown in pics 15 and 16). It looks like the gear was just epoxied to the axel bolt head.
My unit also needed security torx drivers to remove all of the torx screws.
altorennawoodcrafts - Replica
I found the same problem, along with tearing my hair out. 😱
Susang -
Do you know where I could find a belt for the Powerhead? I know its an old vacuum, but there must be similar vacuums that use this size belt. Thank you.
William P - Replica
To nm1hart, I cannot for the life of me find the hidden screw you are referring to. I can wedge up the panel a little on the left of the handle, but not on the right side near the motor. Something is holding it down, but I can't find the screw. Thank you for any help!
Susang - Replica
I followed this to a tee and it worked. The only sad part to it is when i got toward the end i quickly found out that the belt was intact but my motor was frozen internally. Locked up!!! not worth replacing in that case through all away :)
gianstafan291 - Replica
Could you explain how to get the motor compartment panel off. Another poster said there is a hidden screw, but I can't find it. Thanks!
Susang -
I finally found the screw to remove the panel that holds down the the motor cover. It is actually in back of, and underneath, (but behind), the motor cover. Unfortunately words don't describe it accurately. It is really too bad that Ifixit doesn't allow commenters to post a picture in this reply box. That would make all the difference in the world. Also, I'm putting a curse on Shark! They really put a lot of time and effort into creating an almost impenetrable Chinese box. I've probably ruined the vacuum. Sadly, I really loved this vacuum, which is why I bothered to bother...The belt is not broken, just loose, and it looks like the white gear wheel is broken from the metal post that turns the beater brush. Oh well.
Susang - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 101
Tutti i Tempi: 14,353
