Salta al contenuto principale
Shark Rocket Powerhead AH401 Belt Replacement
Cosa ti serve
  1. Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: passo 1, immagine 1 di 3 Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: passo 1, immagine 2 di 3 Shark Rocket Powerhead AH401 Belt Replacement, Brushroll: passo 1, immagine 3 di 3
    • Ensure the device is turned off and unplugged from any power source before beginning work.
    • Locate the two tabs with white arrows on them. They are located on either side of the brushroll cover.
    • Slide the tabs away from the center of the vacuum to unlock the brushroll cover.
    • Lift the brushroll cover upward.
  2. Shark Rocket Powerhead AH401 Belt Replacement: passo 2, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 2, immagine 2 di 2
    • Lift the brushroll out by pulling the tab labeled "pull".
  3. Shark Rocket Powerhead AH401 Belt Replacement, Back Panel Screws: passo 3, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement, Back Panel Screws: passo 3, immagine 2 di 2
    • Flip the device over so that the bottom is face up.
    • Remove the eight screws shown by rotating counter-clockwise with a T15 Torx screwdriver.
    • Two 14 mm Torx screws
    • Two 16 mm Torx screws
    • Four 21 mm Torx screws
  4. Shark Rocket Powerhead AH401 Belt Replacement, Filter Grille: passo 4, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement, Filter Grille: passo 4, immagine 2 di 2
    • Push inward on the top of the filter grille where it says "Push."
    • Lift the filter grille upward.
  5. Shark Rocket Powerhead AH401 Belt Replacement: passo 5, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 5, immagine 2 di 2
    • Lift gently and pull the grille up towards you until it releases.
    • The post-motor filter is underneath the filter grille.
  6. Shark Rocket Powerhead AH401 Belt Replacement, Belt: passo 6, immagine 1 di 1
    • Remove the four screws by rotating counter-clockwise:
    • One 12 mm screw with a T10 Torx screwdriver
    • Three 14 mm screw with a T15 Torx screwdriver
  7. Shark Rocket Powerhead AH401 Belt Replacement: passo 7, immagine 1 di 3 Shark Rocket Powerhead AH401 Belt Replacement: passo 7, immagine 2 di 3 Shark Rocket Powerhead AH401 Belt Replacement: passo 7, immagine 3 di 3
    • Remove the grey filter plate by simply lifting upward.
    • Remove the 14mm screw by rotating counter clockwise with a T10 Torx screwdriver.
  8. Shark Rocket Powerhead AH401 Belt Replacement: passo 8, immagine 1 di 1
    • Remove three 10mm screws by rotating counter-clockwise with a T15 Torx screwdriver.
  9. Shark Rocket Powerhead AH401 Belt Replacement: passo 9, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 9, immagine 2 di 2
    • Remove the airpath grille from the side of the motor compartment by pulling out and away from the attached area.
  10. Shark Rocket Powerhead AH401 Belt Replacement: passo 10, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 10, immagine 2 di 2
    • Remove the motor compartment panel by lifting up and away from the device.
  11. Shark Rocket Powerhead AH401 Belt Replacement: passo 11, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 11, immagine 2 di 2
    • Remove one 14mm screw by rotating counter-clockwise with a T15 Torx screwdriver.
  12. Shark Rocket Powerhead AH401 Belt Replacement: passo 12, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 12, immagine 2 di 2
    • Disconnect the motor side panel by lifting the motor and panel up and out.
    • This step may require some wiggling to loosen the panel before it becomes free.
  13. Shark Rocket Powerhead AH401 Belt Replacement: passo 13, immagine 1 di 1
    • Remove one 9mm screw by rotating counter-clockwise with a Phillips #2 screwdriver.
    • This screw allows the side panel to be removed.
  14. Shark Rocket Powerhead AH401 Belt Replacement: passo 14, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 14, immagine 2 di 2
    • Remove the side panel by pulling the panel out and away from the motor.
    • The side panel is connected with clips which connect near the brushroll axle.
  15. Shark Rocket Powerhead AH401 Belt Replacement: passo 15, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 15, immagine 2 di 2
    • Loosen the two screws by rotating counter clockwise with a T15 Torx screwdriver.
    • The screws only need to be loosened in order to free the belt.
  16. Shark Rocket Powerhead AH401 Belt Replacement: passo 16, immagine 1 di 2 Shark Rocket Powerhead AH401 Belt Replacement: passo 16, immagine 2 di 2
    • Remove the belt by pulling the belt away from the axle.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team S19-G3, Livingston Winter 2018 Membro di Cal Poly, Team S19-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G3
4 Membri
18 Guide realizzate
15 Commenti
These instructions were fantastic accept for one section. On Step 9 you never mention to first remove the Motor Compartment Panel before removing the airpath grille. The picture just shows the panel already removed. Otherwise, I followed the directions forwards and backwards and I was successful!! I went to the local vacuum repair store to purchase a new belt. They did not have the Shark belt so I purchased the Bissell BIBL, BELT geared 80R4, 47A2 for $3.50 and it worked perfectly!!
Liz Needham - Replica
there is a hidden screw on the outside of the compartment/ motor side where the handle mets the motor compartment panel / in the corner iif i could leave a pic i would.
nm1hart -
is the Shark 400 and 401 the same in changing the dive belt?
Alfonso Luna - Replica
What is the replacement belt part#? Did I miss that somewhere here? I can’t find it on their web site or anywhere else on line using the AH401 model #, thanks
Mark Pugliese - Replica
I have an AH452 and the belt number is 4315 SC or Gates # 192-3GT6-SAR
Walt Shuler -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 94
Tutti i Tempi: 14,339
