Salta al contenuto principale
Shark Navigator Lightweight Upright Motherboard Replacement
Cosa ti serve
  1. Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: passo 1, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement, Head Shell: passo 1, immagine 2 di 2
    • Detach the hose connected on the bottom of the vacuum by pulling it out of the casing.
  2. Shark Navigator Lightweight Upright Motherboard Replacement: passo 2, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 2, immagine 2 di 2
    • Lay the vacuum on its side.
    • Press in the black, rubberish button located on the back of the vacuum to detach the vacuum head from the body.
  3. Shark Navigator Lightweight Upright Motherboard Replacement: passo 3, immagine 1 di 1
    • Flip over the vacuum head so the brush head is facing up.
  4. Shark Navigator Lightweight Upright Motherboard Replacement: passo 4, immagine 1 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 4, immagine 2 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 4, immagine 3 di 3
    • Remove the small front wheels with a metal spudger by inserting the metal spudger in front of the wheel and slowly prying up. This will free the wheel and reveal the screw beneath it.
    • Repeat this for the other wheel.
  5. Shark Navigator Lightweight Upright Motherboard Replacement: passo 5, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the two 18mm screws with a JIS 1 screwdriver.
  6. Shark Navigator Lightweight Upright Motherboard Replacement: passo 6, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the four 18mm screws located on the top corners and the bottom/middle of the vacuum head using a JIS 1 screwdriver.
  7. Shark Navigator Lightweight Upright Motherboard Replacement: passo 7, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 7, immagine 2 di 2
    • Remove the two 18mm screws located on the inside of the large wheels using a JIS 1 screwdriver.
  8. Shark Navigator Lightweight Upright Motherboard Replacement: passo 8, immagine 1 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 8, immagine 2 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 8, immagine 3 di 3
    • Remove the plastic cover by prying the plastic cover up using a plastic opening tool.
    • Prying in multiple locations may be necessary to create separation.
  9. Shark Navigator Lightweight Upright Motherboard Replacement, Motor: passo 9, immagine 1 di 1
    • Locate the motor on the top right corner of the vacuum head shell.
  10. Shark Navigator Lightweight Upright Motherboard Replacement: passo 10, immagine 1 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 10, immagine 2 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 10, immagine 3 di 3
    • Remove the belt from the motor gear by sliding the belt to the right.
  11. Shark Navigator Lightweight Upright Motherboard Replacement: passo 11, immagine 1 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 11, immagine 2 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 11, immagine 3 di 3
    • Remove the white metal wire connector from the motor.
    • The white cable is positive.
  12. Shark Navigator Lightweight Upright Motherboard Replacement: passo 12, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 12, immagine 2 di 2
    • Remove the black metal wire connector from the motor.
    • The black cable is negative.
  13. Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: passo 13, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement, Motherboard: passo 13, immagine 2 di 2
    • Remove the two 12mm screws using a JIS 1 screwdriver.
  14. Shark Navigator Lightweight Upright Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the wire housing by removing one 12mm screw using a JIS 1 screwdriver.
  15. Shark Navigator Lightweight Upright Motherboard Replacement: passo 15, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 15, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift up the wire housing from the plastic base using tweezers.
  16. Shark Navigator Lightweight Upright Motherboard Replacement: passo 16, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 16, immagine 2 di 2
    • Free the black and white cables that were previously attached to the motor from their slot.
  17. Shark Navigator Lightweight Upright Motherboard Replacement: passo 17, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 17, immagine 2 di 2
    • Free the motherboard and its connecting parts from the rest of the vacuum.
    • Turn the motherboard upside-down and spread wires out.
  18. Shark Navigator Lightweight Upright Motherboard Replacement: passo 18, immagine 1 di 2 Shark Navigator Lightweight Upright Motherboard Replacement: passo 18, immagine 2 di 2
    • Heat the wire connection's solder joint until the joint looks wet and liquidy.
    • While maintaining contact with the solder iron, free the wire end by pulling the wire away from the board with the tweezers.
    • For instructions on how to solder properly please refer to this soldering technique guide. Come saldare e dissaldare componenti elettrici
    • Remember which cables were soldered onto where. You will have to re-solder the cables back onto the same joint.
    • Solder iron is extremely hot and should be handled with care. Always wear eye protection when soldering.
  19. Shark Navigator Lightweight Upright Motherboard Replacement: passo 19, immagine 1 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 19, immagine 2 di 3 Shark Navigator Lightweight Upright Motherboard Replacement: passo 19, immagine 3 di 3
    • Completely free the cable by pulling it out of the board.
    • Repeat for the remaining cables. There are 4 total.
Conclusione
Suzie
Membro da: 10/02/17
527 Reputazione
4 Guide realizzate
Cal Poly, Team S4-G6, Livingston Fall 2017 Membro di Cal Poly, Team S4-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G6
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,585
