Salta al contenuto principale
Shark NV352 Motherboard Replacement
Cosa ti serve
  1. Shark NV352 Motherboard Replacement, Roller Brush: passo 1, immagine 1 di 2 Shark NV352 Motherboard Replacement, Roller Brush: passo 1, immagine 2 di 2
    • Lift the latches on both sides of the vacuum to release the dust canister.
    • Remove the dust canister from the vacuum by lifting it up.
  2. Shark NV352 Motherboard Replacement: passo 2, immagine 1 di 1
    • Lay down the vacuum to access the bottom panel of the roller brush compartment.
  3. Shark NV352 Motherboard Replacement: passo 3, immagine 1 di 2 Shark NV352 Motherboard Replacement: passo 3, immagine 2 di 2
    • Using the metal spudger, pry the two small wheels located at the two bottom corners of the vacuum to remove them.
  4. Shark NV352 Motherboard Replacement: passo 4, immagine 1 di 2 Shark NV352 Motherboard Replacement: passo 4, immagine 2 di 2
    • Remove the eight 19mm Phillips #2 screws from the plastic cover.
    • Remove the two 14 mm Phillips #2 screws from the upper section of the plastic cover.
  5. Shark NV352 Motherboard Replacement: passo 5, immagine 1 di 2 Shark NV352 Motherboard Replacement: passo 5, immagine 2 di 2
    • You will need to apply a strong force while pulling the wheels off because they are attached very tightly.
    • Remove the wheels by pulling them out of their axles, away from the vacuum.
  6. Shark NV352 Motherboard Replacement: passo 6, immagine 1 di 2 Shark NV352 Motherboard Replacement: passo 6, immagine 2 di 2
    • Perform the next step slowly and carefully so the wiring connecting the motherboard to the rest of the vacuum is not broken.
    • Gently pull the grey lower part of the roller brush compartment away from the purple upper part of the compartment.
  7. Shark NV352 Motherboard Replacement: passo 7, immagine 1 di 1
    • Lift up and then pull the roller belt off of the roller brush and the motor to remove it.
  8. Shark NV352 Motherboard Replacement: passo 8, immagine 1 di 1
    • Take out the roller brush by lifting it out of its tray.
  9. Shark NV352 Motherboard Replacement, Motherboard: passo 9, immagine 1 di 1
    • The capacitors on the motherboard may still hold a residual charge, so avoid touching them because there is a risk of getting shocked.
    • Remove the motherboard carefully so you don't cause damage by pulling the wires connected to it.
    • Lift the motherboard out of the plastic tray to remove it.
  10. Shark NV352 Motherboard Replacement: passo 10, immagine 1 di 1
    • Disconnect the wires connecting the motherboard to the vacuum by unscrewing the twist-on wire connectors.
    • Desolder the wires connecting the motherboard to the motor. Get tips on how to desolder by checking out How to Solder and Desolder.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team S18-G5, Forte Fall 2017 Membro di Cal Poly, Team S18-G5, Forte Fall 2017
CPSU-FORTE-F17S18G5
4 Membri
10 Guide realizzate
5 Commenti
Great work team!
Thomas Smith - Replica
Thanks Thomas! Your support is greatly appreciated!
Vincent Leuzze -
Any knowledge on how to fix or replace the handle lick button. Mine won't lock and so the whole vacuum doesn't work
Jana Butler - Replica
I have a 350 will the 352 powerhead motherboard work as a replacement as I can’t find a 305 one
chaseraymond - Replica
I have a 350 vacume but need a replacement powerhead circuit board would the 352 work? It looks the same and it’s the same unit?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,318
