Introduzione
The motherboard controls the power to the vacuum. If your vacuum is not turning on, your motherboard may need to be replaced. Follow these instructions to access the motherboard for replacement.
Cosa ti serve
Lift the latches on both sides of the vacuum to release the dust canister.
Remove the dust canister from the vacuum by lifting it up.
Disconnect the wires connecting the motherboard to the vacuum by unscrewing the twist-on wire connectors.
Desolder the wires connecting the motherboard to the motor. Get tips on how to desolder by checking out How to Solder and Desolder.
Altre 3 persone hanno completato questa guida.
5 Commenti
Great work team!
Thanks Thomas! Your support is greatly appreciated!
Any knowledge on how to fix or replace the handle lick button. Mine won't lock and so the whole vacuum doesn't work
I have a 350 will the 352 powerhead motherboard work as a replacement as I can’t find a 305 one
I have a 350 vacume but need a replacement powerhead circuit board would the 352 work? It looks the same and it’s the same unit?
