Salta al contenuto principale
Shark ION Robot 750 Button Panel Replacement
Cosa ti serve
  1. Shark ION Robot 750 Button Panel Replacement, Button Panel: passo 1, immagine 1 di 2 Shark ION Robot 750 Button Panel Replacement, Button Panel: passo 1, immagine 2 di 2
    • Before you begin, make sure the vacuum is off.
    • Use a spudger to remove the top case of the vacuum.
    • Flip over the top case.
    • Use tweezers or your hands to remove the center button panel from the socket.
  2. Shark ION Robot 750 Button Panel Replacement: passo 2, immagine 1 di 2 Shark ION Robot 750 Button Panel Replacement: passo 2, immagine 2 di 2
    • Use your hands or tweezers to remove the other button panel from its socket.
    • Use a spudger to pop the panel off of the connector if you need help.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ashley Nguyen
Membro da: 02/08/24
85 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 128
