Salta al contenuto principale
Shark Flex DuoClean Motor Replacement
Cosa ti serve
  1. Shark Flex DuoClean Motor Replacement, Garage Door: passo 1, immagine 1 di 2 Shark Flex DuoClean Motor Replacement, Garage Door: passo 1, immagine 2 di 2
    • Open the garage door by sliding both of the release buttons away from you.
    • Lift off the garage door.
  2. Shark Flex DuoClean Motor Replacement, Side Component: passo 2, immagine 1 di 2 Shark Flex DuoClean Motor Replacement, Side Component: passo 2, immagine 2 di 2
    • Remove the plastic screw covering using a metal spudger by pushing the sharp side into the crevice and prying the cover out.
  3. Shark Flex DuoClean Motor Replacement: passo 3, immagine 1 di 2 Shark Flex DuoClean Motor Replacement: passo 3, immagine 2 di 2
    • Turn the T10 Security Torx screwdriver counterclockwise to remove the 15mm screw.
  4. Shark Flex DuoClean Motor Replacement: passo 4, immagine 1 di 1
    • Use the iFixit Opening Tool to pry the side of the vacuum open.
  5. Shark Flex DuoClean Motor Replacement: passo 5, immagine 1 di 1
    • Remove the side component with your hands.
  6. Shark Flex DuoClean Motor Replacement, Top Component: passo 6, immagine 1 di 1
    • Remove the four 15 mm T10 screws on the underside of the vacuum.
  7. Shark Flex DuoClean Motor Replacement: passo 7, immagine 1 di 2 Shark Flex DuoClean Motor Replacement: passo 7, immagine 2 di 2
    • Using the plastic spudger, pry the back seam of the top component to pop it off the vacuum.
  8. Shark Flex DuoClean Motor Replacement, Brush Motor: passo 8, immagine 1 di 2 Shark Flex DuoClean Motor Replacement, Brush Motor: passo 8, immagine 2 di 2
    • Orient the vacuum so you are looking down at the open garage of the vacuum.
    • Using your right hand, rotate the top of the silver motor towards the brush roll of the vacuum so the motor fits through the opening.
  9. Shark Flex DuoClean Motor Replacement: passo 9, immagine 1 di 1
    • With both thumbs, push the gear on the right side of the motor into the vacuum. The motor should pop out.
    • Slowly pull the motor out of the vacuum base and reveal the electrical cords.
  10. Shark Flex DuoClean Motor Replacement: passo 10, immagine 1 di 1
    • To fully remove the motor, cut the wires.
    • For reassembly, use the soldering guide in the Introduction.
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S17-G5, White Fall 2018 Membro di Cal Poly, Team S17-G5, White Fall 2018
CPSU-WHITE-F18S17G5
4 Membri
14 Guide realizzate
7Commenti sulla guida
Can this motor we test it before taking it out
craigfranz - Replica
Can this motor be tested before taking it out?
How do I know if the motor is burned out
Danny Manuele -
Will you be able to take out the brush roll in front of the motor?
CAM BAP - Replica
Great fix. I wonder if you know how to find a replacement motor? My Dyson motor died and I’m not sure where to start looking for a replacement part - Dyson don’t sell it.
TyN - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 103
Tutti i Tempi: 24,090
