Salta al contenuto principale
Shark AI Ultra AV2511AE Drive Wheel Motor Replacement
Cosa ti serve
  1. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: passo 1, immagine 1 di 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement, Drive Wheel Motor: passo 1, immagine 2 di 2
    • Put the device with the wheel side up.
    • Remove the five 11 mm screws surrounding the drive wheel using a Torx TR15 screwdriver.
    • Gently pull the wheel assembly out.
    • Make sure to pull lightly on the wheel assembly to ensure wires do not rip apart.
  2. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 2, immagine 1 di 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 2, immagine 2 di 2
    • Separate the wire connector from the wheel assembly using an opening tool.
  3. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 3, immagine 1 di 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 3, immagine 2 di 2
    • Remove the spring from the wheel assembly.
  4. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 4, immagine 1 di 2 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 4, immagine 2 di 2
    • Remove the four 7 mm screws around the gearbox using a Torx TR8 screwdriver.
    • Remove the gearbox cover.
    • Be careful about handling the wheel assembly with the gearbox exposed. Debris can enter in and the gears may fall out.
  5. Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 5, immagine 1 di 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 5, immagine 2 di 3 Shark AI Ultra AV2511AE Drive Wheel Motor Replacement: passo 5, immagine 3 di 3
    • If holding the motor vertical, it may fall out once the screws are removed.
    • Using the Phillips #0 screwdriver, remove the two 4mm screws holding the motor to the gearbox.
    • Remove the motor.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 26
Tutti i Tempi: 220
