Introduzione
Use this guide for information on installing a new logic board or re-install the old one. Removing the logic board requires 17 desolders to remove the old logic board. To install a new logic board, then 17 resolders need to be done. Unless you feel very confident in your soldering abilities, you could end up disassembling the the logic board and not be able to reassemble it. Also, be careful when handling the camera after taking the casing off because the camera's capacitor for the flash can shock you. Use this guide to gain access to and replace the logic board.
Cosa ti serve
Remove the following six screws using the Phillips #00 screwdriver:
Two screws on the left side of the camera.
Two screws on the right side of the camera.
Two screws on the bottom of the camera.
Using the spudger, carefully lift up the LCD screen, making sure to keep the ribbon cable intact.
Place the LCD screen on a non-abrasive surface.
Using the Phillips #00 screwdriver, remove the four screws on the outer edge of the LCD holding plate.
Using the capacitor discharge tool carefully touch each end of the capacitor discharge tool to the each terminal of the capacitor.
Click the link below for instructions on how to make the capacitor discharge tool: Costruire uno strumento per scaricare condensatori
Keep the wires connected to the capacitor terminals for 2 minutes to completely discharge the capacitor.
The camera should be completely safe to handle now.
Touch the soldering iron tip to the solder in the upper right corner connecting the logic board to the battery lead.
Pull the battery lead out of the slot in the logic board. This must be done immeadiately after the solder melts.
Repeat for the solder to the left.
The logic board will now be completely free from the camera.
