Salta al contenuto principale
Samsung SPEX SCH-R210 Back Cover Replacement
  1. Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
Conclusione
Austin
Membro da: 07/11/13
201 Reputazione
2 Guide realizzate
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Membro di WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Membri
10 Guide realizzate
1Commento della guida
uh, this is so easy that I’m pretty sure it doesn’t need a guide for it. I found an old Spex (perfect condition except for a few flaws) and I knew how to take off the cover from day 1, but it’s nice you made this anyway. Thx ig
Isaac Kassahun - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 324
